Thread: Intercooler radiator removal without water radiator
    Nov 2012
    Birmingham
    Default Intercooler radiator removal without water radiator
    Hi all,
    Quick question, is it possible to remove the intercooler radiator without the water radiator. They seem to be attached together so I'm thinking both have to be removed and then separated once its off.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Its held on at both top corners with torq screws. So yes you can separate the 3 rads apart. The bottom corners is held by mounts. So undo hoses, only both bottom sides, unscrew top corners, lift it up slightly to get bottom brackets free and bring it down away. Job half done!
    Do same reverse.
    A question, why?
    Nov 2012
    Birmingham
    Quote Originally Posted by Humourbash View Post
    Do same reverse.
    A question, why?
    Yeah, I managed to do it 5 minutes after posting lol. It was the top screws, I found it difficult to get to them, but managed it with the ratchet screwdriver in a bit of an awkward angle.
    And because I hit the car a couple of months ago and either this or the water rad is leaking after being dented inwards. The water radiator looks okay, it's gone ever so slightly inwards at the place of impact in the accident, but it looks fine. It has a little patch where you can tell a liquid has got on, but I think that's just come from the intercooler radiator.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Intercooler dont hold any fluid its air filled. While u're there. Start engine, check for air leak at the intercooler rad, same time inspect where leak coming from, only 2 holds fluid is air con (green) and coolant rad (blue or red depends on which coolant u used)
    Report back...
    Yeah hard to get to but use flexi sockets which makes it easier.
  1. Any tips for fitting water radiator?
    By Whosane in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2013, 19:19
  2. What colour is your radiator water bottle water? and head gasket.
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2011, 21:39
  3. CDTI 120 Radiator and intercooler.
    By sri andy in forum Parts for sale
    Last Post: 17th January 2010, 16:12
  4. Radiator water level light?????????
    By jase44 in forum Electrical & ICE (including SatNav)
    Last Post: 16th January 2009, 20:25
vectra cdti 120 intercooler where is it www.vectra-c.com
