Thread: silly question
    Banned for Being a Numpty
    Jun 2012
    Default silly question
    drained my power steering few days ago and feels very light,scary light....just wandered if i put too much fluid in or sumit? anyone now if the lid that has like a dipstick on it where it suppose to be? and i didnt measure fluid i took out
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    36 Post(s)
    Engine : 1.9 DTH
    Sounds like is too much
    Dec 2011
    Seaham
    If you have put too much in, it would spill out when hot. Maybe the old fluid was knackered and this is how the steering is supposed to feel? Try out a similar car for comparrison>
    Sep 2010
    could be the ice on the ground?! he he!!
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    According to Mr Haynes if you have a standard system with the reservoir behind the wheel arch liner, there are MAX and MIN markings on the side of the reservoir. If you have the compact version with everything mounted down behind the engine, then there is a 'dipstick' on the underside of the cap with stepped diameters (the closest to the cap being the MAX marking).
    Question is, did you bleed the system once you refilled it, by turning lock-to-lock 4 or 5 times then topping up and repeating until settled ?
    Jun 2012
    no i just took old fluid out the resovoir and put new in....not the proper way but it seems to have done somethink....and i thought ice as it gets alot colder higher up u are,but abs never kicked in so i dont know really.....
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Quote Originally Posted by vectraross View Post
    Given I recently moved from Shawbury I know how nippy it gets round your way.... I noticed no real difference in 'weight' of the the steering during the silly cold we had and in ice the ABS kicked in almost as soon as I touched the brake pedal when on icey stretches, so if yours hasn't kicked in I am thinking you might need to bleed and top up yours.
    'Highest point in Shropshire'... how'd you get your car up the Wrekin ?
    Jun 2012
    id get up there easy pal....shawbury is nearer shrewsbury...brown clee highest point in shropshire even higher than long mynd 13th highest in the county i googled that bit,,,,ill check the level tomoz its minus 3 at the min
    Jun 2012
    just a lil pic...see how theres no snow below lol.....
  1. Bit of a silly question but...
    By ijk571 in forum Electrical & ICE (including SatNav)
    Last Post: 15th November 2011, 11:26
  2. A silly question??
    By gaz1965 in forum Vectra C / Signum Car Chat
    Last Post: 15th March 2011, 12:11
  3. Might be silly question.....
    By scotty84 in forum Electrical & ICE (including SatNav)
    Last Post: 20th December 2010, 22:16
  4. Maybe a silly question but hey ........
    By Coastie in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2007, 09:21
  5. Maybe a silly question but hey ........
    Last Post: 13th April 2007, 19:02
