Results 1 to 10 of 19
Thread: Crunching noise on bumps
    Regular Member crazychemist76's Avatar
    North Wales
    Default Crunching noise on bumps
    Anyone got any ideas on this one: I have a 2004 vectra sri v6 cdti, when I go over bumps where the weight of the car lifts then comes back down I get a cruching noise. I have been to vauxhall 5 times and they keep doing work under warranty and not fixing it. I was even told by one chimp at Llangefni Slaters Vauxhall it was the boot lid even though I can feel the crunch by my feet!!!
    Possibly the anti roll bar bushes, or maybe the radiator mounts?
    North Wales
    Had the radiator mounts replaced, I thought maybe the coil springs??? Had the anti roll bar bushes checked and they were fine??
    Has it had the spring seat mod done to it??.. the cruching is usually cured by this..the mod sleeves the end of the coil spring that sits in the spring pan in a nylon tube..
    North Wales
    Not sure about that but I willcertainly be enquiring if it has, what should I ask the dealer if it has had, presumably they will know if it has or hasn't been done.
    just ask them if it has had the mod done.. they will be able to tell without even taking the wheels off...
    I'm pretty sure its the anti-roll bar bushes, mine does the same when its cold, but quiet when warmed up.
    North Wales
    Cheers for that, hopefully that'll be the problem.
    Talking Both of my Vectra's
    Hi, I'm addicted to Vectra's. The latest being my lovely 2002 2.2DTi Elite...
    I thought that moving up to this model would have seen the grating noise disappear, as i've had it on both of my previous 'B' models. Alas, not so, it's back with this one. Only on the cold mornings though. I'd say it's a common problem throughout the Vectra family.
    Not much help i know, but your not alone......
    Yeh your definetly not alone !! Mine is a 2004 sri cdti 150 and has exactly the same noise ,worse when cold but goes away or isnt as noticeable when hot. Didnt know about the mod for the springs so thanks for that! It is booked in for invest on Fri so will let u know the outcome.
  1. crunching and knocking noise
    By 1978spn in forum Suspension, Wheels & Brakes
    Last Post: 17th May 2010, 16:56
  2. Crunching Noise
    By Decker in forum Suspension, Wheels & Brakes
    Last Post: 21st February 2010, 01:31
  3. Crunching sound over bumps
    Last Post: 11th July 2007, 08:04
  4. Crunching noise
    By Silver Vectra C in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2007, 21:55
  5. Crunching sound at rear over bumps?
    Last Post: 19th December 2006, 16:57
