Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: 1.9 cdti engine strange noise
    Nov 2012
    Bulgaia
    Default 1.9 cdti engine strange noise
    What makes this strange noise when opening the throttle? Thanks in advance for any suggestions.
    http://www.youtube.com/watch?v=M9IWjIU4-J8&feature=plcp
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Sounds like the gearbox? Does it do it when you press the clutch pedal?
    Nov 2012
    Bulgaia
    No, it doesn't. It's present when moving and in neutral over 1800 - 2000 rpm.
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Aux belt to tight
    Nov 2012
    Bulgaia
    Thanks guys! Is it somerhing easy to diy/solve. Are there any how 2's?
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Remove the axillary belt, run the engine see if the noise has stopped, if so probably one of the bearings on the Aux belt run, check each one by hand for play and rough turning.
    But..........
    If the noise is still there, take it to a garage and have the timing belt inspected, a decent garage will know what too look for, I don't recommend you start to remove the timing belt covers and poke around in there unless you have done the job before
    Carnoustie
    Mine is doing this also! very similar, maybe not as bad but same noise, not got to the bottom if it yet, things that have been done, timing belt kit, new water pump, new alternator and tensioner (belt was ok) that just leaves one pulley near the ac pump or the ac pump itself?
    Ronnie
    New Member chapas's Avatar
    May 2012
    Portugal
    Vehicle : Opel Vectra C
    Engine : 1.9 150hp
    Mileage : 120000
    Hello,
    I have the same noise. but do not know what can be
    Thx
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    Mine sounded like that just before the alternator fell apart, so could be the alternator or aux belt.
    Carnoustie
    Quote Originally Posted by ghostrider View Post
    I thought it was the alternator on mine but sadly no, that's 3 of here with the same noise, doubt I will get the chance to remove the aux belt anytime soon, would like to see how the others progress.
    can anyone rule out this being a turbo problem?
    Ronnie
  1. Strange noise from offside engine 2.0T
    By Steven in forum Engine & Drivetrain
    Last Post: 16th December 2012, 10:44
  2. Strange Engine Noise
    By CraigoT in forum Engine & Drivetrain
    Last Post: 13th November 2011, 18:08
  3. Strange noise from engine compartiment...?!?!?!?
    By Maxim007 in forum Engine & Drivetrain
    Last Post: 11th January 2011, 17:50
  4. strange noise from engine cdti 150
    By kamar in forum Engine & Drivetrain
    Last Post: 12th April 2010, 17:16
  5. Strange engine noise
    By Jim Bob in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2007, 18:01
vectra 1.9 noise at 2000 rpm
