Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: advice, i was sold the wrong spec!
    Regular Member Lee..'s Avatar
    May 2007
    Chesterfield
    Default advice, i was sold the wrong spec!
    hi all, a week ago i bought an insignia sri vx line 2.0 cdti with sat nav, i have the advert number and sales number which match, it says nav 600 and mine is a 500. what should i tell them i want. or what should they do? cheers Lee
    Regular Member keith1983's Avatar
    Sheffield / Spalding
    Vehicle : Vectra 1.8 SRi
    Engine : Z18XE
    I'm not familiar with the Insignia specs but I presume what you're saying is that the sat nav unit in your car is not the one that was on the specification sheet? If this is the case I'd tell them you want uit upgrading to what you have paid for or some sort of monetary settlement. Are you happy with the 500? Also what is the difference between a 500 and a 600?
    May 2007
    Chesterfield
    vauxhall have told me the difference is an sd card slot and the 500 needs the cd in all the time so i can't use the cd player at the same time as sat nav. WHICH IS #### !!!
    Regular Member graham a's Avatar
    hull
    lee,you pre load the disc onto the 500 then remove it.how old is the car?,as the 600 came out around july last year
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Quote Originally Posted by Lee.. View Post
    A quick Google says Apparently you should be able to transfer the maps to the internal memory.
    Not sure if this is correct, but I dont believe you wont be able to listen to a CD while the nav is on
    edit: Graham beat me to it
    hull
    Quote Originally Posted by Ziggy View Post
    you can listen to your music ziggy
    Engine : Z18XE
    I think your first step should be to contact the vendor and see what they say, then if they don't offer you an acceptable resolution maybe head over to trading standards or the citizens advice bureau for advice on how to follow it up?
    Full Member
    South West
    I made all the inquiries about the difference between the 500 and 600. And as stated the 600 uses the sd card and 500 a cd which you load to internal memory.
    Annyoing I know, but of the rest of the car is upto spec, take the dispute to the dealer and ask for compensation. No idea what to ask for...? I was unsure which unit was in the car I was going to buy, but was convinced not to let it be a show stopper as the difference is so negligible. The dealer should certainly stump up.
    Mine was advertised with Bluetooth, then got told it didn't. Got a nice chunk knocked off - enough to have it retro fitted! Then found out if you actually turn it on it works!!! Aidi 1 - Dealer 0.
    Forum Moderator & Events Team davedrinks's Avatar
    Sep 2010
    Luton
    20 Post(s)
    Vehicle : Vectra Hatch
    Engine : 1.8VVTi 16v
    Mileage : circa 28K
    As others have said, the CD500 Nav is CDROM based and selected maps can be downloaded onto an internal flash drive in the headunit - however, you can't download all the maps as there isn't enough space (it tells you the size of each map when you go into the download map section under config...navigation (iirc that's where it is!). Once downloaded you remove your map disc and use the cd drive for listening to music(& possibly mp3) CDs.
    The Navi 600 is SD card based and that is kept in a slot under the armrest next to the USB socket & Aux In, and you still have a CD slot available in the head unit. The Navi 600 also differs in that you can program in your own POI (I think - I know the Navi 900 you can do this!) into the system.
    They probably won't be able to easily replace a 500 with a 600 btw, so they probably won't go for that option! If your sales contract/receipt states the model number of the nav then you could try and get compensation - if it doesn't then it's a matter of if they are prepared to offer you some goodwill I guess!
    HTH
    Mods : Insignia Washer Jets,Boot & Footwell LEDs,Reverse Cam,Pioneer AVH-3200BT,Pioneer TS-Q172C(front),Alpine MRVT407 V12 Amp,Alpine SBE-1243BR 12" Sub,In Car Freeview TV,Heko Wind Deflectors,Airbox mod,K&N Panel Filter,Irmscher Boot Spoiler,Angel Eyes, 50W 5K HIDs, 30mm Lo lowering springs, Eyebrows,17" Fox Alloys,Powerflow Stainless Steel dual exhaust. Winner-Best I.C.E-Heritage Centre Meet 2013
    May 2007
    Chesterfield
    the car is an 11 plate, the advert says sd slot and navi 600, i got it from vauxhall (bristol street motors) last week, they have told me today it says navi500 on the man-spec at production, i cant find a menu to install it or any memory options.its a small thing but it seems like they have dropped a ######.
  1. exclusive spec vs club spec
    By rjw in forum Vectra C / Signum Car Chat
    Last Post: 13th March 2012, 20:10
  2. Sold a car privately advice required
    By steveked in forum The 'Off Topic' room
    Last Post: 10th February 2011, 11:19
  3. Replies: 5
    Last Post: 19th November 2008, 22:16
  4. Wrong place wrong time.
    By silverhairedracer in forum General Chat
    Last Post: 29th October 2008, 14:20
