Thread: nasty intermittent noise 120 8v
    Nov 2011
    devon
    Vehicle : vectra 1.9 cdti
    Trim : sri
    Engine : 120 8v
    Mileage : 151k
    Default nasty intermittent noise 120 8v
    right guys. i had a little chirp noise which i know was probably the aux belt a while back,which seemed to go away til the other day.then whilst out earlier ,after getting to destination,it was making a lot more noise ,some of it squealy,some almost grindy.after getting back out an hour later we started it up and it was briefly there on start up,then went,till next stop about 3 miles away.again,came back and it went away,till next stop and it started again on pulling in.it goes from higher pitched to more rubbing/grindy and back,so whats the first thing?
    about 10 miles from home so wondering if its worth a free rac call out ?
    Nov 2011
    devon
    Trim : sri
    Engine : 120 8v
    Mileage : 151k
    just thought of one thing ,when i blipped it when it had the noise it seemed to reduce /stop it?
    Nov 2010
    East Midlands
    8 Post(s)
    Trim : design
    Could be alternator bearing, tensioner bearing, idler bearing, air con compressor bearing causing your 'grindy' noise - alternatively could be coming from the cambelt pulleys/tensioner or water pump - if its squealing more than likely to be on the auxillary belt side I would think and usually the alternator
    Nov 2011
    devon
    Trim : sri
    Engine : 120 8v
    Mileage : 151k
    well thing is we got aa out already and guess what,it didnt do it .took it out to get it to do it,nothing.he had a good look over,said the aux belt looks sweet and straight and couldnt hear anything untoward.held the revs up for a while and got nothing.he was apologetic not giving any clue,but said best thing is when its doing it get local mechanic(got one i trust) to have a listen and se what happens.seems to be worse when hot,but only really when coming to a stop and like i said it clears when blipped or left to go cold.but will look out for anything and post it.cheers
    Nov 2010
    East Midlands
    8 Post(s)
    Trim : design
    Can't be a deal wrong with it and if it is a bearing on the way out the noise will gradually get worse and give more indication whereabouts it is - I would have thought if it was anything he would have picked up on it. I would just keep a very close eye on it.
    Nov 2011
    devon
    Trim : sri
    Engine : 120 8v
    Mileage : 151k
    well quick update,since tuesday afternoon it hasnt done it once,so really confused,as although i am no top mechanic,it definately wasnt pleasant and i think next time i may try doing a vid on my phone to post up for any idea's.if it happens again that is!
  1. Getting nasty noise over big bumps
    By JaceyBoy in forum Suspension, Wheels & Brakes
    Last Post: 18th May 2012, 20:56
  2. my gearbox has a hole in it and is making a nasty noise.!!
    By Vectra boy in forum Engine & Drivetrain
    Last Post: 13th February 2012, 20:20
  3. Drivers door.nasty noise when opening & closing.
    By Dobs in forum Bodywork & Interior
    Last Post: 5th November 2011, 01:16
  4. 1.9 CDTi Intermittent smoke, smell, noise..
    By Sten in forum Engine & Drivetrain
    Last Post: 5th August 2011, 17:33
  5. Nasty graunching noise from front :(
    By AntSSSS in forum Vectra C / Signum Car Chat
    Last Post: 21st February 2010, 23:45
