Thread: 1st gear issue
    Sep 2011
    Newport
    Default 1st gear issue
    Hi All,
    Had a good look on the forum and can't seem to see what I'm looking for, so hoping that someone can help.
    OK, bit of background info.....I have a Signum 2.0DTI 05 plate, just covered 130,000 miles. Had the clutch and flywheel changed at 124,000 miles.
    Sunday started having a few issues with 1st gear, when the car is stationary 1st gear will select without an issue, can pull off fine and no issue going into second, however when stuck in traffic or coming up to a junction I cannot select 1st gear. When moving 1-2mph trying to go into 1st is a no go. Sometimes it will slip in not an issue, however today it is getting worse, have to put the car into neutral, stop the car still and then it will slip into first not an issue, cannot go from second to first at all.
    Spoken to a few of my mates and they are suggesting something to do with a synchro mesh?? Might not even have that right lol.
    Don't know if it has got something to do with the clutch being changed not so long ago, although the clutch itself seems fine, or the gearbox has finally given up the ghost!
    I don't drive the car hard at all, okay we all do it, sometimes I do give it a boot when we get a chav in a corsa thinking they are the best thing since sliced bread, but apart from that I have always looked after the car.
    I know it's done a lot of miles, but surely the gearbox could not have given up the ghost already??
    Any help would be great!
    Jul 2011
    UK
    Year : 06
    Have the same problem I've just had new clutch and flywheel and a gearbox replacement and it will struggle to go into 1st say I reverse out the drive then go to put in first it won't go In without little force my car is a cdti 150 tho
    Regular Member Das's Avatar
    Turdsville
    35 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Not an expert but it does sound a bit like the 1st gear syncro is failing, as thats its job, to allow you to select gears when moving. 130k is pretty good going, someone lost their gearbox(diff) at 70k a couple of weeks back. Should be easy enough to pickup a good second hand box.
    Jul 2011
    UK
    Year : 06
    Quote Originally Posted by Das View Post
    That somebody was me lol
    Sep 2011
    Newport
    So with this in mind, do I pay to get the gearbox recon'd or do I get shot of the old girl? This is all I need with Christmas around the corner!
    Jun 2012
    Stourbridge
    In the mean time, teach your self to double clutch?
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2016, 16:15
  2. Gear link or box issue
    By GCusdin in forum Engine & Drivetrain
    Last Post: 23rd January 2013, 19:04
  3. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  4. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
  5. Vec C 52 plate 2.2 Dti Gear Stick Jumps out of 1st gear on take off
    By ukwanderer01 in forum Engine & Drivetrain
    Last Post: 5th July 2009, 21:43
