Results 1 to 10 of 14
Thread: Engine cut out! DPF regen on start up
    Regular Member ScottyV6's Avatar
    Feb 2011
    Worcester
    Default Engine cut out! DPF regen on start up
    Driving into work this morning, I was doing a little italian tune up on my car on a dual carriage way (engine was up to temperature). cruising at 4000RPM for 30 seconds in 3rd gear I then went to accelerate before changing into 4th, then wallop, Loud pop type noise also felt like brakes were pushed hard for a milisecond, both warning lights on and engine cut out! thankfully I was within a 100 yards of a parking lay-by. I then pulled over, attempted the pedal trick to see if any codes, and nothing. I then restarted and drove off as normal, car then pretty much immediately went into DPF regen. I don't know if the 2 are linked as I had to interrupt its regen yesterday.
    Could it be the dreaded SCV?
    Feb 2011
    Worcester
    Basically felt like the engine stalled at 4500RPM
    Feb 2011
    Worcester
    Just been and bought a new fuel filter from the stealer's. and filled 5L jerry can up with fuel to top up diesel on fuel filter change. Now sat in work stinking of diesel because I spilt it! Having a great day. Also car booked into garage next Monday that I bought it off, as still within warranty. I will update on this later. Thank you for reading.
    Regular Member renodci's Avatar
    Kent
    Hope you get this sorted with the garage ScottyV6. I'm interested to hear you talk authoratively about your car going into DPF regen; I see you've got an '04 V6 cdti - mine is an '05 V6 cdti and I understood from someone on here that cars with the Y30DT engine weren't fitted with DPF's. Previously I believed that Y30DT's with an auto box WERE fitted with DPF's......now I'm just confused! Are you able to shed any light?
    Feb 2011
    Worcester
    Sorry buddy didn't notice my profile said 2004! Just changed it now. It's a 2006 55 reg facelift. Sorry to cause confusion.
    also I believe the stealers have sold me the wrong fuel filter, GM 95507489. Back tomorrow, I did question it when they charged me £12 for it, and the grumpy parts guy assured me it was correct.
    Regular Member ghostdog's Avatar
    Apr 2011
    Ayrshire
    Let us know how you get on ScottyV6
    Regular Member Swedge's Avatar
    Jul 2012
    Scottish borders
    when my car starts a regen it dosnt stall or anything, just feels pretty sluggish and a bit of smoke out the back, mine isnt a v6 though just a 150cdti
    Feb 2011
    Worcester
    Ok! Changed the fuel filter this morning.
    car started on 2nd attempt, so pretty happy with that.
    Should I have pre soaked my new filter? The reason I ask is, now when accelerating at low revs the car pulls smoothly, no more judder.( didn't realise I had a judder, just thought I was in too high a gear) However when I was accelerating up the dual carriage way in 3rd gear the car hesitates at 3000rpm and a couple of times, through up spanner light, and limited revs to 3000rpm. So pulled over both times turned off and on, and carried on with drive, still jumpy/hesitant around 3000rpm but not in 1st or 2nd gear. Idle is perfect! My idle instant mpg has gone from 0.3 to 0.2.
    when I say hesitates, it's like not firing on all cylinders, and no codes.
    it is booked into the indie that I bought it from on Tuesday, but that is just a used car sales place that has its own mechanic (still got 1 month left on warranty)
    so do I need to let filter soak?
    do I enquire into scv's?
    do I let the car learn again?
    cheers everybody!
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Give it time to fully soak up on its own. Yeah soak it with fuel first before fitting... But it'll start to expel any air in there.
    Feb 2011
    Worcester
    Thought it might be that! Thank you!
  1. Key fob not letting engine start
    By cyberbobdude in forum Vectra C / Signum Troubleshooting
    Last Post: 20th June 2012, 18:07
  2. Engine and Spanner Light Before I Start The Engine
    By corderz in forum Engine & Drivetrain
    Last Post: 24th March 2011, 18:48
  3. engine rattle on start up
    By craigyboy in forum Engine & Drivetrain
    Last Post: 13th October 2009, 19:35
  4. 1.9 CDTI (150) Engine won't start
    By koolrunner in forum Engine & Drivetrain
    Last Post: 20th April 2008, 11:04
  5. Engine died and won't start!
    By Snoddy in forum Engine & Drivetrain
    Last Post: 6th January 2008, 18:10
