Results 1 to 10 of 18
Thread: '05 Vectra C Estate Suspension Failure
    May 2012
    Devon
    Default '05 Vectra C Estate Suspension Failure
    Hi all,
    well yesterday after leaving work I noticed a click coming from the front nearside seemingly only happening when turning right.
    Having had various French cars in the past that regularly suffer from worn bearings in the top shock mount, this struck me as the same sound and feeling that I had had before.
    I was on the case trying to find a top mount with bearing as soon as I got home.
    This morning my wife took the Vectra to work and about 5 minutes after she left my mobile rang and I answered to her hysterical voice.
    Apparentely, while driving along there was a clunk after going over a dip, not pothole, in the road.
    As there was nowhere safe to stop she went on a bit and started noticing some smoke coming from the nearside front along with a rancid burning rubber smell.
    A few other drivers were flashing at her and not far along she found a safe place to pull over.
    I had to rescue her and had a good look at the car.
    The front nearside wheel is quite a way up in the arch but the tyre is not flat.
    I checked under the car and the sump tray has no signs of damage, so that didn't scrape along the road.
    I would say that there is about 2 inches of clearance between the road surface and the underside of the track control arm.
    There is no damage to the strut turret looking at it from under the bonnet.
    I have read various reports that the coil springs fail on these Vectras, coud what I have explained be this happening to mine?
    Am currently waiting for a garage to tow and fix the car now.
    Nice, loads of £'s just before crimbo.
    Carnoustie
    Happened to me, the spring pinged out and was digging into the tyre wall! could need a new tyre too
    Ronnie
    May 2012
    Devon
    Quote Originally Posted by ronnie63 View Post
    Ronnie
    Cheers Ronnie.
    when you say the spring pinged out, do you mean that it wasn't actually broken but just needed re-seating?
    How can the spring just pop out of it's seat, does this mean there is damage to the seatings on the strut itself?
    Regards..,
    Carnoustie
    Quote Originally Posted by MadTogger View Post
    Cheers Ronnie.
    Regards..,
    Yes it had broke near the bottom so car was still sitting at ride height but using the steering just screwed the spring out of it's seat and then it dug into tyre, mine being the estate also.
    Ronnie
    May 2012
    Devon
    OK, so a new spring and tyre was all that was needed then?
    Carnoustie
    Yes I would say so, fairly common for the springs to break, sometimes you don't find out until mot time! so fingers crossed it wont cost a fortune!
    May 2012
    Devon
    I think the most expensive part is probably going to be the recovery.
    My 1st choice local garage were unable to do anything for at least 2 days, 2nd choice were too busy also but they put me on to another garage that can tow the car today and do the work tomorrow.
    I'll post back the outcome.
    Regards..,
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    could look in local paper and find a mobile mechanic, if you want it done sooner then no messing about having to recover car to a garage if its at your home, you should really replace both sides.
    May 2012
    Devon
    Quote Originally Posted by 06sri View Post
    Unfortunately the car is about 2 miles from my home, stuck in a tiny layby, otherwise, yes, good idea thanks.
    Jan 2010
    Perkinsville, County Durham
    Trim : Sri nav
    Engine : Z19dth
    Worth checking the back end for broken springs too.
  1. Replies: 41
    Last Post: 6th September 2012, 20:38
  2. Is a split suspension gaiter and MOT failure?
    By carperjake in forum Suspension, Wheels & Brakes
    Last Post: 30th July 2012, 21:33
  3. suspension vectra c 3.0 V6 CDTI elite Estate
    By kop 76 in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2010, 21:29
  4. vectra estate front suspension creak?
    By bigsteve in forum Suspension, Wheels & Brakes
    Last Post: 15th February 2010, 15:10
  5. Replies: 22
    Last Post: 30th July 2009, 14:15
