Results 1 to 3 of 3
Thread: Battery light on 5 minutes after starting
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default Battery light on 5 minutes after starting
    is there a car map that shows every earthing points?
    One i want to do is find earthing point for all things that relate to battery light on dash as all parts work spot on, just fed up with battery light appearing after i drive 5 minutes after starting and stays on but battery remains 14.1v running, 13.8/9 with radio on light on etc.
    Kinda want to solve that issue once and for all!!!
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Is it genuine alt fitted?
    Check voltage on main alt wire
    check voltage on smaller plug believe its a blue/ white wire
    Voltage between both wires.
    In answer to your actual question tis2000 has all the earthing blocks shown in a diagram
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Quote Originally Posted by Critch View Post
    Its a replacement by vauxhall as stated in the service book. There is screw on type wire fittings. No plug. I have other alternator from a 1.9 150 sri z19dth engine in perfect working order. Just dont understand why my car isnt a plug but screw on type.
    Voltage is good on computer so dont know why. Til friend said earthing loose so thought i compact that by locating the point for alternator.
    If not solved. I'll have to try and retrofit original alternator plug to my wirings and fit that alternator in attempt to solve the issue if i can find the plug
  1. Replies: 10
    Last Post: 10th July 2012, 11:18
  2. spanner light on for first few minutes
    By bridge_eee in forum Engine & Drivetrain
    Last Post: 15th May 2012, 19:25
  3. Vectra not starting / battery light
    By graham22vti in forum Vectra C / Signum Car Chat
    Last Post: 14th June 2011, 14:56
  4. Car not starting, battery issues??
    By Adz86 in forum Electrical & ICE (including SatNav)
    Last Post: 5th November 2009, 08:57
  5. Battery Light comes on after 3 minutes of Driving
    By bren in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2008, 18:08
vauxhall vectra-c battery light on
