Results 1 to 10 of 17
Thread: Engine Replacement
    Jan 2012
    High Wycombe
    Default Engine Replacement
    Hi,
    How much of a job is it to change out an 2.0dti engine from my vec c to a slightly newer one, reason being is i think its on its way out, sounds awful and loads of people have said to me it sounds bad also. changed the oil on it to see if it would improve, was told to put in 5w30 and since then, once warm i get the oil pressure light on or flickering when idleing? mileage is now 158000
    Seem some second hand ones for about £200-£300, is it worth a chance? what sort of cost am i looking at to swap one. I hear you have to code the pump to the new engine also?
    Last thing how do i find my engine code to double check im buying the right one for my car, just ring up vauxhal and ask or is it stamped anywhere. Its an 53plate vec c estate
    Nov 2012
    Birmingham
    Quote Originally Posted by madvortex View Post
    Hi,
    Your engine is "Y20DTH".
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Try 10w40 oil
    and put 1/2 litre of 2 stroke oil in with a full fuel tank and see if makes it sound any better
    Nov 2010
    East Midlands
    Trim : design
    Bit of a gamble fitting a £2-300 engine could be as bad as the old one - make sure you can hear it running in the donor car and also ask if there is any history supplied with it.
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    Quote Originally Posted by alcutler View Post
    thats about there price then you need to add about the same again for fitting you can swop over your own fuel pump
    mine (a 2.2 dti) has been noisey for over 2 years now about 50,000 miles and has now 180,000 mile on it and still going strong
    people told me all sorts of horror stories of why it was noisey ie. the crank is about to snap the timimg chains are going to break
    as critch said stick some 10w40 and new filters in and drive on
    i have my own suspision it is the inlet manifold gasket some day i will change it
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Change to 10/40 oil and get the oil pressure checked by a garage. If the oil pump is getting weak it might be the noise is coming from that.
    Serbia
    You have problem with oil pressure- must change bearings on crankshaft immediately- better do not drive a car until you fix becauose crankshaft maybe snap!
    Regular Member Swedge's Avatar
    Jul 2012
    Scottish borders
    Quote Originally Posted by Agolubovic78 View Post
    the crankshaft wont snap, itll just knacker the journals which will require a regrind and oversize bearings
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Hi,
    Read all the link below see if sounds like your problem.
    Quote Originally Posted by Swedge View Post
    http://www.vectra-c.com/forum/showth...ed-Crank-Shaft
    Jul 2012
    Scottish borders
    from oil starvation, christ i didnt think it could do that
  1. 3.2 auto engine replacement
    By leedavis1971 in forum Engine & Drivetrain
    Last Post: 27th September 2012, 18:25
  2. Possibly looking for replacement engine... 1.9CDTi
    By Ross-SRi in forum Vectra C / Signum Car Chat
    Last Post: 20th July 2011, 22:46
  3. engine replacement - DIY
    By whiskyno7 in forum East (RO - WhiskyNo7, ARO - Plasma)
    Last Post: 16th March 2011, 20:03
  4. replacement engine
    By rednail in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2010, 21:45
  5. Replies: 5
    Last Post: 17th October 2009, 12:04
