Thread: Question about unplugging egr valve
    Jun 2012
    Brechin
    Trim : Sri
    Engine : CDTi 150
    Mileage : 116k
    Default Question about unplugging egr valve
    Hi again lads. CDTi 150
    is there any bad implications caused by running your car with the egr unplugged as opposed to blanking it?
    I use an enclosed cone filter on my car just tone and when the egr was plugged in I used to get a nice chatter/ whoosh noise when backing off the throttle ( I know it's not terribly good for it ). But since unplugging it this noise has stopped, any reason why that might be?
    also a couple months back I unplugged the egr for a couple days then plugged it back in. A couple days later the copper pipe that comes off the manifold burst, costing a pretty penny. Was this caused by unplugging my egr?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Yes everytime it goes for an MOT you need to plug the valve back in as the light will fail the MOT. Also there is a chance the valve is not fully sealing so may be letting gases through to the inlet manifold. The only real way is blanking and having the valve mapped out.
    Jun 2012
    Brechin
    Trim : Sri
    Engine : CDTi 150
    Mileage : 116k
    Anyone?
    Jan 2012
    Gloucestershire
    I'm not sure what the copper pipe is or does, but no, unplugging the EGR would not cause any pipes to burst in my opinion. The EGR allows exhaust gas to be recirculated back through the inlet manifold in an attempt to give unburnt fuel a second chance to burn rather than going straight out of the exhaust. The EGR is however closed at some running conditions even when plugged in and so long as the exhaust system (pre-cat, DPF if you have one etc.) itself isn't restricted in some way the exhaust gas should just find it's way straight out of the exhaust pipe when the EGR is closed.
    Jun 2012
    Brechin
    Trim : Sri
    Engine : CDTi 150
    Mileage : 116k
    The copper pipe is the one that goes around the engine from the exhaust manifold to the back of the egr valve. No I don't have a dpf so I should be okay!
    Jan 2012
    Gloucestershire
    Ok, so it's the connection from the exhaust to the EGR. These shouldn't burst! There is even a GM part number for a Fiat "blanking plate" which if fitted is the equivalent of (or similar to) unplugging the EGR, only you don't get the eml due to the electrical connection error - the hole in the plate is only large enough to let through some exhaust gas, similar to what the EGR lets through when unplugged/closed.
    So, either you had a defective/damaged pipe or you had a large back-pressure in your exhaust system causing the pipe to burst. I'm not sure what else would cause it, but I'm not a mechanic so maybe someone else will come up with a more likely reason.
  1. Throttle valve question??
    By the_riddler in forum Engine & Drivetrain
    Last Post: 4th February 2012, 20:15
  2. EGR Valve question
    By CH-VECTRA-ELITE in forum Engine & Drivetrain
    Last Post: 8th July 2011, 16:11
  3. Another EGR valve question
    By aerodynamic18 in forum Diesel Engine related
    Last Post: 11th February 2011, 18:39
  4. EGR Valve Cleaning Question
    By corderz in forum Diesel Engine related
    Last Post: 31st January 2011, 21:57
  5. Unplugging The Egr valve !!
    By DeanF in forum Diesel Engine related
    Last Post: 16th May 2008, 21:58
