Results 1 to 10 of 17
Thread: windscreen washer help
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Vehicle : Vectra C estate
    Trim : SRI
    Mileage : 79000
    Default windscreen washer help
    My washer jets have stopped spraying water but the pump in the bottle is still making a noise.
    I have disconected the pipe going into the first jet but nothing is coming out.
    Any ideas?
    newport
    pull the pump out the bottle (in front of passenger side front wheel arch, then pull the little mesh filter out and clean it, probably gunked up, had to do it to a few cars now
    Regular Member puppet's Avatar
    East Ayrshire
    10 Post(s)
    Vehicle : Insignia 1.8 SRi
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    Quote Originally Posted by taffy bhoy View Post
    This. It's a common problem on the Vectra.
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 79000
    i pulled the pump out but cant see a mesh filter, is it inside the hole where the pump goes?
    cheers
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    When you pull the pump out, you then pull the black rubber mounting/grommet out ... the mesh is formed into the lower end of that.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Go to local garage and ask mechanic to use his blow line down the washers works every time ;-)
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 79000
    cheers all, will have a look in the morning and failing that will get my m8 to blast the line through
    cheers
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by Critch View Post
    Where do you connect the air line to the pipework going back to the filter? And if you managed to do that you will only be blowing the gunge back into the washer reservoir - when I cleaned mine out it was like a thick gob of slime - which would soon work its way back to the filter and block it again
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Quote Originally Posted by alcutler View Post
    Just put it on the washer jet it's self.
    i agree chances are over time. it may build back up again but providing you use a good quality screen wash shouldn't have much of a problem
    usually needs doing to make a customers car ready to pass MOT etc.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
  1. Windscreen washer
    By hadiislam in forum Electrical & ICE (including SatNav)
    Last Post: 14th May 2012, 21:33
  2. Windscreen washer
    By Alansvecky in forum Electrical & ICE (including SatNav)
    Last Post: 8th December 2011, 12:46
  3. Windscreen Washer Jets
    By John Bishop in forum Electrical & ICE (including SatNav)
    Last Post: 2nd December 2010, 12:46
  4. Windscreen washer problem
    By heheshamon in forum Vectra C / Signum Troubleshooting
    Last Post: 7th February 2010, 14:54
  5. Windscreen Washer Motor
    By cae2020 in forum Vectra C / Signum Car Chat
    Last Post: 28th August 2007, 21:31
