Thread: Help needed...with A/C switched on should heater fan spin even when set to 0 position
    Regular Member marky2027's Avatar
    Northumberland
    Default Help needed...with A/C switched on should heater fan spin even when set to 0 position
    Having loads of problems troubleshooting interior fan problems. I think it's all sorted now but I've noticed a strange thing. When the heater control is in the off/0 position and the air con off the fan doesn't move. If I turn air con on but leave the fan in the off position the fan starts spinning on the number 1 speed..........is this normal or is the heater control panel bust.
    Regular Member beat275's Avatar
    Aug 2011
    Newcastle West Denton
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    Your gonna have everyone running to there car to see lol
    Barrow In Furness, Cumbria
    Yes, it's normal.
    Northumberland
    Quote Originally Posted by Chris SRi View Post
    Yes, it's normal.
    Thank God for that........had the heater control panel in bits, changed relays, new thermal fuse on the resistor......then when i noticed that I thought....what have I done??!!
    Just got to drill into the bottom the fan housing tomorrow following the how 2 on here and I'm all done. Hopefully it will all be sorted
    11 Post(s)
    Yes, it's normal.
    It's to prevent the system icing up by creating some airflow.
  1. Heater Blower Issue - Only works on Position 4
    By phughes64 in forum Electrical & ICE (including SatNav)
    Last Post: 8th October 2015, 21:09
  2. Help needed please heater resistor/relays
    By readbri in forum Electrical & ICE (including SatNav)
    Last Post: 2nd February 2013, 11:24
  3. help needed ( heater question)
    By CallumHill in forum Vectra C / Signum Troubleshooting
    Last Post: 20th January 2013, 13:26
  4. Heater Blower Issue - Only works on Position 4
    By phughes64 in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2012, 20:47
  5. Help needed with throttle position sensor
    By olid2002 in forum Engine & Drivetrain
    Last Post: 15th January 2011, 15:05
