Results 1 to 10 of 14
Thread: cdti 150 coolant temps, is this normal?
    Jan 2012
    Dublin
    Default cdti 150 coolant temps, is this normal?
    The temp gauge on my cdti 150 is a bit of a strange one. Its my first diesel so not sure if its normal or not.
    I can do a non-stop 5 hour motorway journey and the temp gauge will sit on 70degrees the entire way, ie not move from cold.
    I have the heat set slap bang between hot and cold and the fan on setting 1 so the vents arent sucking much heat out of the coolant. Occasionally the temp needle might move up to 73ish degrees but thats only on a warm day. Now if i then hit city traffic, stop start the temp will suddenly rise to 90+degrees.
    Is this normal on these engines? Just find it odd how the temp doesnt go up despite hours of use but will rocket in city traffic. It'll then go right down to nothing once the car is moving on the open road. Lol is this normal or have i just got a seriously effective radiator?
    Regular Member Mission1979's Avatar
    Castleford
    Engine : 1.9CDTi
    Mileage : 113000
    Mine did this from when I bought it until about five months ago when I changed the thermostat. Now it sits about 86 degrees after it gets to temperature after about ten minutes. Get one from dealer, cheaper than most most spares places.
    newport
    just bought a new thermostat with housing and new sensor already fitted to it from vauxhall today for our 1.8 with identical problems, £44 all in with the discount i get from another site,
    Regular Member keith150882's Avatar
    Oct 2009
    boston
    Vehicle : Cdti 150
    Trim : Sri
    Same here! I just put it down to when your do 65-70mph in 6th gear car is only doing 20-2500rpm so it's only just ticking over but if traveling on B roads with a bit of gas it sits at about 80
    Jan 2012
    Dublin
    righto i'll change the thermostat so, thanks for the replies guys. Been a while since i worked on a z19dth, its on the gearbox end of the head isnt it?
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Classic thermostat issue mate on the CDTI's - get a genuine VX only one.
    A
    Regular Member mike.'s Avatar
    Oct 2012
    peterborough
    Trim : SRi NAV
    Engine : 1.9 CDTi 120
    I had this issue when I bought mine, fitted a thermostat and now sits around 80 degrees
    Regular Member stevoxsi's Avatar
    Sep 2012
    Coleraine, Norn Iron.
    Vehicle : Insignia
    Trim : Sri Vx-line
    Engine : 2.0 Cdti 160
    Year : 2011
    Me too! Get a thermostat in her!
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Quote Originally Posted by IrishVectra View Post
    Its next to battery. Stand on nearside and look, 4 hoses attached with plug.
    Regular Member mrk's Avatar
    Vehicle : vectra hatchback
    Trim : improving
    Engine : 1.9cdti mas remap
    Year : 06
    would this effect mpg? i average 42 mpg and tp rarely goes above 75°
  1. normal cdti 150 temp??
    By elite_150 in forum Engine & Drivetrain
    Last Post: 6th June 2012, 08:57
  2. Coolant line..is this normal?
    By Maurice in forum Engine & Drivetrain
    Last Post: 21st September 2010, 10:55
  3. CDTI 150, is it normal for it not to smoke ?
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 14th June 2010, 19:12
  4. cdti 150 back to normal
    By michael cummings in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2009, 19:57
  5. 'normal' coolant temp
    By Mike57 in forum Engine & Drivetrain
    Last Post: 9th July 2007, 20:27
