Thread: Intermittent starting problem?!?
    Regular Member TAB's Avatar
    Nov 2012
    Forest Town, Mansfield, Notts
    Vehicle : Vectra C VXR
    Trim : VXR Fully Loaded
    Engine : 2.8 Turbo, remapped
    Mileage : 65,000
    Default Intermittent starting problem?!?
    Hi folks,
    Odd one, every now and then the car wont start, its like the battery is dead, just clicking and interior lights flashing when key is turned, and will always start straight away with jump leads or rolling bump?
    I thought it was due to the cold or prolonged non use (sometimes go days without using it) but last week or so its done it whilst out and about, i stopped to check tyre pressures today and it wouldnt start when i got back in? So it had been running no problems, was warm etc?!
    If it was alternator then wouldnt it be constantly struggling to start? rather than odd times? (usually the most inopportune moments isn't it too?)
    Just to add it isnt even trying to 'turn over', just clicking
    Any ideas?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Battery
    Aug 2012
    Keep a jump lead in the car. The next time its refusing to start put the jump lead from your battery negative to a good metal part on the engine and try again. If it starts you got a bad earth if it doesn't you didn't get a good bit of metal on the engine or the battery is on its way. Its worth noting that a battery in the cold will reduce capacity by more than a 1/3.
    Nov 2012
    Mileage : 65,000
    I'll try that thanks )
  1. 2006 CDTI Intermittent engine not starting
    By Dbus in forum Engine & Drivetrain
    Last Post: 9th June 2014, 22:37
  2. Intermittent starting on my 2004 1.9 CDTI 150
    By burgher in forum Vectra C / Signum Troubleshooting
    Last Post: 30th November 2012, 12:50
  3. 2.2 dti intermittent starting/low down problem
    By cybergen in forum Engine & Drivetrain
    Last Post: 23rd April 2011, 18:07
  4. 1.9 cdti intermittent starting problem (air leak?)
    By moff747 in forum Engine & Drivetrain
    Last Post: 16th April 2011, 15:54
  5. Signum intermittent starting problem
    By kildrum in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2011, 22:34
vectra c intermittent starting
vauxhall vectra intermittent starting problem
intermittent starting problem vectra
intermittent starting 55 plate vectra
intermitant starting problem 2003 vauxhall vectra
intermittent starting vectra c
vectra c p2103 intermittent starting
vectra intermittent starting fault
