Thread: steering track control arms
    Regular Member rfc52's Avatar
    Aug 2012
    Stonehouse
    Vehicle : vectra
    Trim : 1.9cdti sri 150
    Engine : diesel
    Default steering track control arms
    Hi guy, i had the car in to get the free inspection at vauxhall and picked up the radiator leak i have and knew and also said both steering track control arms have a bit of play in them and need replacing..
    are these pricey?, and are they easy to fit?.
    thanks in advance..
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    They ain't too dear bout £20 a side bit of a git to fit and you need a huge spanner as well 32 or 36mm spanner can't quite remember
    Aug 2012
    Stonehouse
    Vehicle : vectra
    Engine : diesel
    cheers chris
    Regular Member pipamish's Avatar
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    I need these also and I got priced at Vauxhall at £45 something each hth
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    You need one of these:
    http://www.ebay.co.uk/itm/Inner-Tie-...-/250958225147
    Much easier than farting about with a large spanner etc
    Are you VXR Enough
    13 Post(s)
    Quote Originally Posted by pipamish View Post
    not if you use the trade card fella
    Regular Member farley2708's Avatar
    antrim n.ireland
    i tried the spanner thing............................................. ........would have filled a swear box no problem!!!!!! till i got one of these
    20 mins the old one was off & the new 1 on,fiddliest bit was the 'clip' on the large end of the rubber boot/cover
    Regular Member sheepish's Avatar
    Yorkshire
    But you need to counterhold the steering rack when you're doing it, and there is only a flat spot for this on the off side (if I remember correctly), so it really helps to have a helper...
  1. upper control arms
    By chris1804 in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2012, 18:55
  2. For Sale: Upper Control Arms
    By Danger_MouseUK in forum Parts for sale
    Last Post: 5th August 2012, 17:15
  3. Rear Control Arms
    By thegoldenbullet in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2011, 18:33
  4. trying to do control arms
    Last Post: 3rd December 2009, 23:08
