Results 1 to 10 of 15
Thread: 2.0t engine help
    Regular Member roverjay's Avatar
    Feb 2012
    Skelmersdale
    Vehicle : Vecta
    Trim : sri
    Engine : 1.8
    Mileage : 39000
    Default 2.0t engine help
    My 2.0 t signum has just started to smoke it is white and stinks lol any ideas I've read the codes with my cheap odd scanner and all I was p0300 which is random misfire ?
    Dec 2011
    Seaham
    Have you checked the brake fluid level? Possible for brake fluid to be sucked through the servo and into the inlet manifold.
    Feb 2012
    Skelmersdale
    Vehicle : Vecta
    Trim : sri
    Engine : 1.8
    Mileage : 39000
    Quote Originally Posted by Ben50n View Post
    ill go check in a min is this a commom fault if so just a master cylinder then i hope
    Dec 2011
    Seaham
    Not a common fault, just one that I know can cause white stinking smoke and not the first place to look. Normally you should be checking your coolant level, but I expect you have already looked at that??
    Feb 2012
    Skelmersdale
    Vehicle : Vecta
    Trim : sri
    Engine : 1.8
    Mileage : 39000
    Brake fluid still full water and oil seem fine nothing mixed or lost. Plus the smell is weird
    Dec 2011
    Seaham
    Have you power washed your car and filled the exhaust with water?
    Ely, Cambridgeshire
    60 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Mine's been doing exactly the same the last couple of weeks (also a 2.0T), loads of white "smoke" and a really strong smell on start up. But as soon as the car's warmed up it stops. I put it down to the system using a higher choke setting because of the cold weather and more fuel going in and to condensation in the exhaust system.
    Feb 2012
    Skelmersdale
    Vehicle : Vecta
    Trim : sri
    Engine : 1.8
    Mileage : 39000
    I thought about that but it seems to do it when warm aswell. It was fine this morning did a 20 mile journey mainly dual carriage ways pulled up at a post box and got a whiff of something wrong drove home about 1 mile checked under bonnet for the usual leaks mixing etc but nothing wrong someone just suggested it could be a coil pack I'm going to risk driving it to him and chuck his snap on reader on it
    Ely, Cambridgeshire
    60 Post(s)
    Year : 2010
    I think that's the main difference, I'm not getting any errors logged or other issues. The error you're getting would point towards coil packs potentially so they could well be right. It's quite common for them to go on the 2.0T's
    Feb 2012
    Skelmersdale
    Vehicle : Vecta
    Trim : sri
    Engine : 1.8
    Mileage : 39000
    just had all plugs out and number 1 cylinder has loads of smoke coming out of it were as the other 3 are fine is this pointing towards valve stem oil seals or worn rings or possibly head gasket had it on snap on code reader and no codes present so i think its looking exspensive
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 15:24
  3. Replies: 35
    Last Post: 5th May 2012, 15:32
  4. Yellow engine light staying on & engine getting hot.
    By Phil Campbell in forum Engine & Drivetrain
    Last Post: 20th March 2010, 08:56
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
