Results 1 to 10 of 16
Thread: Clever members, whats it called n purpose??
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default Clever members, whats it called n purpose??
    As title, what is (pictured below) it called? And it's purpose?
    I'm trying to narrow down internal heating issue,
    Fan blows fine all settings,
    Red lever motor by glove box moves fine
    Heater matrix both hoses (flow and return) equally hot
    Its either this (pictured above) or the flaps within the whole air cabin box!!
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Can't see if too clearly but is it the heater control servo?
    morecambe
    43 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Looks like it matey
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    What does it do?
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Quote Originally Posted by Critch View Post
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Quote Originally Posted by Humourbash View Post
    What does it do?
    We're not that clever
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    opens and closes the flap to the heater matrix and I suspect the part I need to replace on mine as it ticks when turned to fully cold
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Quote Originally Posted by john norris View Post
    Ahhh. I was kinda hoping it was not that but most likely mine's on the blink! As I'm only getting warm heat. Barely warm by time it reach our face!! Due to cold weather and troubleshooting, could not find the problem. Due to using cabin air box I took them apart and learnt a great deal about it from a donor car. So will I be able to fit that part to my manual as the part I got came from car that have auto on the heater panel... Please say yes!!! I'm planning to attack and replace today.
    Cant drive in cold car all the time with 1 yer at old baby and 8 year old!!
    Anyone reckon it'll be that???
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    If you manually move the red/ pink lever does that then give you hot air?
    Are both heater matrix pipes hot?
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    The red lever moves freely, i even adjusted it by hand. Still give same warm air.
    Both pipes hot in engine bay. Was thinking to shine light inside and see if flaps controlled by red lever is moved.
    Also test one at top that got motor servo as well, it seems it controls direction of air. Its all black motor and arms.
  1. whats this called?
    By richje100 in forum Engine & Drivetrain
    Last Post: 15th January 2013, 21:43
  2. Whats It Called ? lol
    By Tam80 in forum Bodywork & Interior
    Last Post: 6th March 2011, 21:47
  3. Whats it called??
    By kman247 in forum Bodywork & Interior
    Last Post: 11th April 2010, 16:21
  4. whats it called
    By willoftoon in forum The 'Off Topic' room
    Last Post: 13th July 2008, 19:11
  5. Whats it called? ICE help
    By rushy in forum Electrical & ICE (including SatNav)
    Last Post: 29th May 2006, 23:05
