Results 1 to 3 of 3
Thread: Auto Gearbox - Can you prevent Water Contamination?
    Essex
    Default Auto Gearbox - Can you prevent Water Contamination?
    Hi
    Can you prevent water contamination getting into the Auto gearbox? Can you change the seals before they perish?
    I see a previous post mentions they re-designed the radiator so water contamination is not possible is this correct and if so from what year did this take place?
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Just an after market oils cooler will do it mate
    Devon
    Quote Originally Posted by paulvectrac View Post
    I agree! An aftermarket cooler gives you 100% peace of mind, and much more efficient cooling of the ATF, which should make the box last the lifetime of the car (as long as you change the fluid every 3 years or so)
  1. Auto Gearbox Contamination? REcall/Rework?
    By Nezza42 in forum Engine & Drivetrain
    Last Post: 12th July 2012, 05:47
  2. Gearbox contamination
    By topaz in forum Engine & Drivetrain
    Last Post: 25th January 2010, 23:46
  3. Water In Facelift Auto Box
    By bowler in forum Engine & Drivetrain
    Last Post: 26th November 2008, 19:03
  4. Gearbox Coolant contamination
    By Will Glenn in forum Engine & Drivetrain
    Last Post: 2nd July 2008, 18:23
  5. sounds like water in my gearbox??
    By tap69bingo in forum Engine & Drivetrain
    Last Post: 6th December 2007, 17:23
