Results 1 to 10 of 20
Thread: Intermittent Lambda ?
    Regular Member JagRigger's Avatar
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    Default Intermittent Lambda ?
    A couple of months ago I had an emissions light come on. Fault code 0136 - the downstream lambda on the flexi pipe. It went off after a couple of days short trips, when I drove for 20 miles plus, pulled in for petrol, and never came on again.
    This morning it did it again. Three small journeys all with the light on. One longer trip, park up and lo - it's gone out again.
    On both light coming on occasions it was wet.
    Do you reackon it is a damp connection drying out, or symptomatic of a failing sensor that needs a good heat up to work properly ?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    It's for the front sensor that code an is a heater element code.
    could be a poor connection or internal fault.
    Need to test with a multimeter to confirm
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    OK - at this point HELP
    I changed the front lambda for a new NGK one - light still on ( now constant )
    Just changed the rear too for a new, more generic Denso one.
    Damm light's still on with an 0136 code...............
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Have you cleared the code?
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    Nope - but surely the( emissions ) light should go out even if the code is still stored
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 142000
    have you left the car standing for a while?
    http://www.vectra-c.com/forum/showth...ult-Code-PO136
    clear the codes
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    Quote Originally Posted by JagRigger View Post
    Ive been told that codes can take up to 10 days to clear themselves. Try disconnecting the battery for half an hour.
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    Car does around 50 miles a day, so not been left.
    Just went out and disconnected the battery - will leave it off overnight and see if that clears the code.
    I tested the old lambda heater and got 10 ohms across it - which is worryingly normal, so maybe I have a loom issue. Anyone know what readings I should be getting supplied to the lambda ?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 142000
    sorry i dont know the readings
    lets hope it resets it self in the morning
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    Well - it didn't reset.
  1. EML 2.0T Lambda or CAT
    By a1ant in forum Vectra C / Signum Troubleshooting
    Last Post: 20th August 2011, 20:53
  2. Cat Or Lambda
    By Tam80 in forum Vectra C / Signum Car Chat
    Last Post: 6th July 2011, 21:03
  3. Lambda help
    By Barnes in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2010, 20:42
  4. lambda sensor
    By deg in forum Vectra C / Signum Car Chat
    Last Post: 2nd November 2009, 18:35
  5. Lambda
    By VECTRAMAN in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 10:33
