Thread: 1.9 150 Diesel injector removal
    Apr 2012
    durham
    Default 1.9 150 Diesel injector removal
    Hi im looking for the best method of removing injectors on a 1.9 150 diesel engine. I have soaked with plus gas and tried pulling them out by hand but no luck. I have heard about attaching a slide hammer to the top of the injector to pull it out, any ideas will help.
    Regular Member vmb2722's Avatar
    May 2012
    Blackpool/St Mary's Bay
    5 Post(s)
    Trim : Exclusiv
    Engine : 1.9 CDTi 150
    slide hammer best way, another way is to loosen the clamp slightly and fire the engine, pressure should loosen the injector enough for removal by hand! slide hammer is the safest choice tho
    Apr 2012
    durham
    Thanks for the info im hoping they come out without any damage.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Easy job, two large flat blade screwdrivers prising at each side will pop them out easily, Hole can be cleaned out with a garden hose attached to ur vacuum cleaner.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Quote Originally Posted by the-wizard View Post
    Exactly how I have done it
    Hanging Heaton / Batley
    16 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Is it the bolts/brackets that have jammed or the injectors themselves, my 04 with 100k just popped off by hand?
    Apr 2012
    durham
    The engine has done 50k miles, the brackets are loose, tried by hand no luck. I only tried with one screwdriver should have tried two DOH!. I have purchased a injector puller just waiting for it to arrive, i need the head off the engine hence the reason for removal.
    Apr 2012
    durham
    Just an update on the injector removal, tried with two large screwdrivers still would not move, so i bought a slide hammer with the attachment for the injector and managed to remove all four two came out ok the other two needed a bit more work they were seized into the bores, the plus gas had worked its way down the sides so helped with removal.
    A tip for anyone doing it this way you need to remove the top of the injector to attach the slide hammer but be careful there is a spring, washer and colet to collect when the top is removed.
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    I let my seized injectors sit in diesel overnight then, tapped them back and forth till they loosened up
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    I used a large adjustable and wiggled back and forth and it came free pretty easy
  1. Diesel injector seals failed after 18 months!!!
    By ads3 in forum Engine & Drivetrain
    Last Post: 22nd June 2012, 15:44
  2. removal and replace cdti injector
    By bygumlad in forum Engine & Drivetrain
    Last Post: 12th February 2012, 17:56
  3. injector removal
    By leehuggy72 in forum Vectra C / Signum Troubleshooting
    Last Post: 21st April 2011, 11:34
  4. Plastic diesel input into injector
    By oxenburger in forum Vectra C / Signum Car Chat
    Last Post: 9th March 2010, 22:36
  5. Diesel injector recall
    By Diesel Dude in forum Vectra C / Signum Car Chat
    Last Post: 16th October 2008, 21:54
Z19DTH injector removal
how to remove a diesel injector from a vectra
1.9 cdti injector removal
how remove injector on vauxhall cdti
vauxhall vectra injector removal
1.9 cdti injector puller
vauxhall injector removal tool
how to take injectors our of a vectra
z19dth injector seals
how to remove an injector out of a Vauxhall Vectra diesel
cdti 150 injector removal
buy injector pully for vaxhall vectra 1.9 cdti
how to remove diesel injector 2008 vectra
how to remove vauxhall injectorssaab 9-3 diesel injector removalHow to remove vauxhall astra injectorsastra h 1.9 replace injectorshttps:www.vectra-c.comforumshowthread.php176792-1-9-150-Diesel-injector-removalastra h replace injectors 1.9z19dth injectorsvauxhall insignia injector remove toolopel vectra c injector forumastra diesel injector removalvectra 1.9 cdti sri injector removal
