Thread: Garage base.
    Regular Member Tinks's Avatar
    Jan 2012
    Whittlesey
    Vehicle : Vectra C Elegance
    Engine : 1800
    Mileage : Lots
    Default Garage base.
    Hi all,
    Just a bit of general advice really.
    Has anyone on here laid a concrete base for a garage??
    If so, how much and what size was it??
    Cheers all
    Tony
    morecambe
    39 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Pending on the size 4-6 inch mate just asked my dad he's had quiet a large civil engineering company lol
    Jan 2012
    Whittlesey
    Engine : 1800
    Mileage : Lots
    Paul, cheers for that mate, who better to get advice from!!!
    I had heard "rumours" that it should be 8" but will see how the back fairs with the shoveling!! lol
    Thank your dad for the advice and thanks to you for passing it on.
    Tony
    May have more questions - they may be silly - for your dad nearer the time.
    Regular Member veclee's Avatar
    Nov 2012
    skegness
    Vehicle : vectra c
    Trim : club
    Engine : 1800
    Mileage : 63000
    dependant on main uses will determine the thickness of base and grade of mix needed if it is just for general use of parking on then 4" think and a gen 1 mix would be fine
    VIP-Member antowens's Avatar
    Dec 2011
    liverpool
    ours is 6" thick with re-bar through it to strengthen it works sound with a concrete garage on
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    If you need it 6in thick, then make it 8in thick ..... better to overdo it a little than to have to sort out repairs and reworks later.
    Nov 2012
    skegness
    Vehicle : vectra c
    Trim : club
    Engine : 1800
    Mileage : 63000
    if it needs to be more than 6" think theres some serios work going on it we do farm yards and sheds 6" loading docks warehouses the lot at 6" with a252 weld mesh in it unless its spersificly requested by a structural engineer due to bad ground ie silt peat but if your puting a brick wall round the footings need to be a foot thick to carry the walls then the floor would be fine at 6" provided the sub base is done right the floor will be fine dont be fooled in to chucking 2" chalk at it and thinking ist ok you need 6" think chalk or limestone base made for 2" stuff the topped with 1" down rolled or wacker plated would be ok then cover it over with a sheet of dpm (damp prof membrain) when doing concreting make sure out side temp is above 5 deg and they is no frost forcast over night and you should be fine and finish with a good result ive never had a complaint in 17 years of constuction
    Nov 2012
    skegness
    Vehicle : vectra c
    Trim : club
    Engine : 1800
    Mileage : 63000
    oh and to calc the amount witdh x length x depth = cubic meters required ie all mesurments in millimetres
    3.0m x 6.0m x 0.1m = 1.8 cube
    10 foot x 20 foot x 4" = 1.8 cube
    if you need it working out to a size your using give us a shout and i'll gladly work it out for you
  1. dab aereil base
    By hippo in forum Vectra C / Signum Car Chat
    Last Post: 3rd June 2011, 22:12
  2. How much??? Aerial base.
    By watchman in forum Electrical & ICE (including SatNav)
    Last Post: 23rd April 2011, 17:48
