Results 1 to 7 of 7
Thread: electrics going crazy help please !
    Regular Member adam_vaux's Avatar
    Oct 2012
    nottingham
    Vehicle : vauxhall vectra c
    Year : 2003
    Default electrics going crazy help please !
    Vectra 1.8 ls 2003
    Went to start my car today and when I turned the key nothing happened apart from all lights flaahing stereo started blasting out and the alarm was going away ! Took the key out could lock the car using key fob so had to lock manual . Walked away from the.car with the stereo and alarm still going off . Tryed jump starting it off my other car started fine , drrove a few miles down the road and all the lights were flashing again , lost power steering and car died then all electrics started goina mad again had to disconnect the battery to get some sleep !! Lol . Can anyone lead me in the right direction please ? Is it the.battery , alternator ??
    Regular Member Handyandy-UK's Avatar
    Mar 2009
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    If you have access to a multimeter you need to check the battery voltage (engine off) and then at idle and with some revs (around 2000rpm should do). You're looking for about 12v engine off and around 14v running - slightly higher just after starting, but settling to around 13.5v.
    If you don't have access to a meter, most battery places will do a check for you - some even free.
    Once you can eliminate battery and alternator faults, you can better hunt down anoy other possible problem(s).
    Jan 2011
    scottish region
    It's the alternator mate
    Glasgow
    As above alternator.
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    If you don't have a multimeter get yourself to local Halfords they'll perform a check and give you a print out
    Oct 2012
    nottingham
    Year : 2003
    Looks like it was the alternator will try get one orded thanks lads !
    Regular Member SlowCoach's Avatar
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Engine : Z19DTH
    Year : 2008
    Mileage : 105000
    I had that happen. Turned out starter motor packed in. Alternator charges battery when engine running, starter motor plays a role with alternator as well. Take alternator and starter motor to reconditioning electrical place to be tested. Free!
  1. Crazy
    By bigmac in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2011, 09:55
  2. Electrics gone crazy.
    By Martinlw in forum Electrical & ICE (including SatNav)
    Last Post: 8th December 2010, 16:47
  3. Crazy people, crazy drivers.
    By Grumpy1954 in forum General Chat
    Last Post: 8th October 2010, 19:42
  4. Now This Is Crazy!!!
    By Jay Kay 313 in forum Comedy & Humour
    Last Post: 16th November 2008, 13:41
  5. Going Crazy
    By Kevin JC 1.8 in forum Vectra C / Signum Car Chat
    Last Post: 31st October 2008, 15:54
renault scenic electrics gone mad
Renault scenic electrics going crazy
