Thread: Coolant Levels - Advice Required Please
    Apr 2012
    Default Coolant Levels - Advice Required Please
    Hi,
    Is it normal for Coolant levels to drop during the Winter/Autumnal months when using the heating in the car or do I have a leak somewhere. I've checked all of the the hoses/pipes that are visible & there doesn't seem to be any leaks.
    What would be the best course of action to take please?
    Best Regards
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Coolant level will sometimes drop under normal use, but if it a sudden significant drop you will more than likely have a leak
    3.2 v6 Signum and loving it
    Banned for Being a Numpty
    Jun 2012
    check ur oil mate
    Quote Originally Posted by Panacea View Post
    The coolant system is sealed, so should not lose coolant unless there is a leak
    At the temperature increases it becomes pressurised
    If the coolant level falls then this suggests poor flow, as the result of a blockage
    The most common cause is the radiator
    Therefore next time the car is hot put your hand on the radiator and compare the difference in heat between the top and bottom
    The top should be less hot than the bottom
    If there is little difference then it is likely to need replacing
    Equally, if the temparature gauge fluctuates a lot and the radiator fan is coming on, then this too suggests the radiator has reached the end of its life
    Sep 2010
    north east uk
    Surely that should be the other way around?....the top of the radiator hotter than the bottom?
  1. Advice required about ECU
    By Kyser143 in forum Engine & Drivetrain
    Last Post: 4th November 2010, 23:43
  2. 3.2 SRI V6 advice required
    By chrisgg90 in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2009, 02:32
  3. Help Advice required
    By Graeme in forum Engine & Drivetrain
    Last Post: 4th December 2008, 00:35
  4. Advice Required please
    By Stivagorm in forum General Chat
    Last Post: 21st June 2008, 06:04
  5. coolant levels
    By shy_stag in forum Vectra C / Signum Car Chat
    Last Post: 9th October 2007, 20:47
vectra c 3.2 v6 what radiator coolant site:www.vectra-c.com
