Thread: Why does a knackered thermostat................
    Regular Member carperjake's Avatar
    Scunthorpe
    Trim : Elegance CDTi 120
    Engine : 1.9
    Default Why does a knackered thermostat................
    affect MPG? I've noticed my consumption drop by around 10mpg recently, the thermostat's the thing I was thinking of first as it doesn't move much anymore. Just can't get my head round why the MPG should be so adversely affected.
    Anyone?
    Regular Member Beardy's Avatar
    Oct 2012
    Thetford
    Vehicle : Astra
    Engine : 1.7 CDTI
    Mileage : 110,000
    iirc the engine cannot get to its optimum running temp so will either run too hot or cold and engines are designed to run with very tight tolerences.
    Oct 2012
    Thetford
    Vehicle : Astra
    Engine : 1.7 CDTI
    Mileage : 110,000
    basically too hot and components expand and become too tight and if too cold not tight enuf
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Coolant temp effects the fuel mix. Cold engine = more fuel etc. all part of the ecu map.
    Scunthorpe
    Engine : 1.9
    Cheers.
    11 Post(s)
    I notice from your profile you've got an oil burner.
    I'm guessing the garages are now selling winter diesel.
    That'll make a difference to the fuel consumption.
    Mar 2012
    wakefield
    Vehicle : vectra v6 cdti
    Trim : sri
    Mileage : 70000
    10 mpg is a massive drop,noticed about 3-4 mpg loss when mine packed in
    Regular Member Exclusive BV's Avatar
    West Midlands
    i think the reason is due to the programming in the ecu.
    it is set to deliver a certain amount of fuel until the car gets to a certain temp
  1. My DPF is knackered! Help!
    By rockafella8587 in forum Engine & Drivetrain
    Last Post: 6th March 2012, 15:46
  2. Think my key is knackered
    By vectrasri20t in forum Bodywork & Interior
    Last Post: 26th February 2010, 12:01
  3. Im knackered.....
    By PAULMAC77 in forum General Chat
    Last Post: 14th April 2009, 09:51
  4. I'm knackered!
    By AJA in forum The 'Off Topic' room
    Last Post: 10th February 2008, 15:48
