Thread: vec c 1.8 thermostat problems, symptoms?
    newport
    Default vec c 1.8 thermostat problems, symptoms?
    just want to clarify before ordering a new one
    car drives a1
    temp guage slow to get off the bottom,
    at idle, it will get up to temp, around 92, fans kick in, and drops below 90
    if driving in stop start traffic it does the same, but slower
    if up to motorway speed or running at normal speed, temp needle drops down to nothing again within a couple of mins, and will stay there until in stop start traffic again or idling
    my money is on thermostat, but just want to make sure. its a 2003 1.8
    i had this problem on my last 1.8, but only replaced the spring part inside the housing, this fixed the problem for around a year, then the problem came back again, so going to change the whole thing this time
    Jun 2011
    Buckley Flintshire N.Wales
    Vehicle : vectra
    Trim : .....................
    Engine : ....................
    Year : .....
    Sounds very much like it bud
    Barrow In Furness, Cumbria
    Yep, sounds like the thermostat.
    Regular Member sheepish's Avatar
    Yorkshire
    It will be the spring part inside again, just buy a better quality one and it should last longer.
    Regular Member Exclusive BV's Avatar
    West Midlands
    defo sounds like the stat to me
    do you get any heat from the blowers?
    newport
    sorted, £44 from vauxhall for new thermostat with housing, sensor and seal, 20 mins to change, then bleed the system, job done, nice and toasty heating now, which stays hot even when cruising, needle starts to move about 2 mins after driving. all sorted
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 138000
    Quote Originally Posted by taffy bhoy View Post
    car drives a1
    the same happened to me with the above symptoms common fault on the vectra c 1.8
    mine broke around 53000 miles
    your mpg will be better now
    newport
    hoping so,
    Nov 2012
    cumbernauld
    just got my car a week or two ago notice the temp whe down to 70 with the heaters on and just below 80 when driving had a quick look at the howto on here got the part number i needed for the thermostat itself ad bobs your ucle cars heating a treat. Can drive the car though cause i changed the thermostat and the pump but the tensioner I got isint any good. Ill have to get it all apart again this weekend and put the new tensioner in and will be good to go did take the car for a wee drive thought and the temp stayed steady with the heater on full bung when driving. Did cool down a bit on idle with heating on full but thats oly to be expected.
    Regular Member Wolfie01's Avatar
    Nov 2010
    Wolverhampton
    I also have the 1.8 2003 model having read this thread last night kept an eye on my thermostat gauge this morning. Temp outside was -2c drove 15 miles at speeds of 20/30mph before the needle decided to move even then it only move slightly. The next 10 miles of my journey the needle sat at 75 whilst moving and moved up to 80 when in traffic by the time I had completed the 24 miles journey it was sat at 75. I've only just had the car serviced including anti freeze flush.
  1. 1.8 vvt (Z18XER) Thermostat Problems
    By sambuka in forum Engine & Drivetrain
    Last Post: 11th January 2013, 21:27
  2. Thermostat and other problems maybe? Advice please!
    By daz1409 in forum Engine & Drivetrain
    Last Post: 3rd June 2012, 22:48
  3. EGR symptoms
    By tobybongo in forum Engine & Drivetrain
    Last Post: 12th October 2008, 21:32
  4. dmf symptoms
    By tommy tess in forum Engine & Drivetrain
    Last Post: 30th May 2008, 21:14
  5. Symptoms Of Being Over 25…..
    By Inspektor in forum Comedy & Humour
    Last Post: 22nd February 2006, 15:47
