Thread: Strange noise from my Vectra CDTI
    Sweden
    Default Strange noise from my Vectra CDTI
    Hi guys..
    I need some ideas to what the sound in the video is???
    http://www.youtube.com/watch?v=Y_Ak9T2opYA&feature=plcp
    Thx
    Jakob
    Hanging Heaton / Batley
    21 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Have you tried lubricating any of belt guides/pulleys?
    Sounds like the cars practicing its drum skills, a little bit of a hi-hat solo... da da tss, da da tss, da da tss... lol
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Aux belt or pulleys
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Engine sounds sweet!, you could try a little squirt of 'rubber & nylon lubricant' on the aux/flat serpent belt, you can buy this from halfords store or similar motor factors.
    Sweden
    Aux belt and one pulley was replaced a week ago, but with no change in the sound...
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    the dust covers have a habit of rubbing on the pulleys i bent them out a little and greased them up a little put them on and sound went away
    Aug 2012
    fuel pump may make this sound when ignition is on (no that loud though!!!) to final stage without engine start. Does it make this noise with ignition fully on without engine running?
    Just to be sure about aux belt pulleys. Remove it and start engine an see if the noise is there.
    Also check condition of the timing belt.
    Could even be aircon but taking the aux belt off and trying it will narrow this down anyway
    scottish region
    timing belt ???? when was it last changed
  1. Strange Noise on Start Up From Cold 1.9 CDTi 150
    By smallwheels38 in forum Engine & Drivetrain
    Last Post: 11th June 2016, 15:33
  2. 1.9 cdti engine strange noise
    By n1ks0n in forum Engine & Drivetrain
    Last Post: 10th January 2013, 00:49
  3. strange noise from engine cdti 150
    By kamar in forum Engine & Drivetrain
    Last Post: 12th April 2010, 17:16
  4. Strange sucking noise CDTI 120
    By GoldenWonder in forum Engine & Drivetrain
    Last Post: 6th October 2008, 18:56
