Thread: Cd70 and CID question
    Regular Member davidlewis24's Avatar
    bridgend / wales
    Default Cd70 and CID question
    Hi everyone just a quick question for anyone that has a cd70 and CID anyway when i put the key in and turn mine on the screen lights up with the vauxhall logo then it jumps straight to my mpg screen and not the cd/ music screen I'm pretty sure it used to and it realy annoys me lol I know I only need to scroll over to the cd page but I'd like to see if I'm correct so what screen dose yours go to when you turn it on please ?
    Thanks in advance
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Pretty sure mine defaults to the audio screen, Without taking a gander through the handbook though I couldn't tell you if you can set the default screen or not. I'll have a read in daylight - might get an asnwer unless someone beats me to it.
    scottish region
    Mine goes straight to cd is the ignition logic ticked in settings
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    tick logic in settings.
    Dec 2011
    Seaham
    Agree tick the ignition logic in settings, the BC is always on, but you have to set the auto start up of the radio.
    Full Member Robsey's Avatar
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    Sounds like an ignition logic setting issue in the [SETTINGS] screen.
    I only get this if I manually turn off the head unit (and leave it off) before removing the key from the ignition.
    Alternatively, your display may have had a little hiccup.
    If this is the case, try disconnecting the battery fo 5 mins or so.
    (but not within 5 mins of having the engine on or the ignition on)
    This should force a soft reset of the modules...which will then reboot properly.
    Does the radio work manually?, if not check the folowing...
    Make sure that fuses 1, 12, 17, 19 & 26 at the end of the dash are all clean and secure.
    Especially fuse 1... Oh and the 15amp fuse in the back of the head unit.
    bridgend / wales
    Thanks everyone ill have a little look now
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    Any answers to this fella?
  1. Cd70 question
    By chrisvectra in forum Electrical & ICE (including SatNav)
    Last Post: 15th February 2012, 01:36
  2. Another CD70 question
    By dholbon in forum Electrical & ICE (including SatNav)
    Last Post: 2nd August 2011, 20:47
  3. cd70 question
    By mr bh in forum Electrical & ICE (including SatNav)
    Last Post: 1st June 2010, 21:23
  4. cd70 question
    By davidlewis24 in forum Vectra C / Signum Car Chat
    Last Post: 27th December 2009, 20:26
  5. CD70 ID3 Tag Question
    By AndySkinner in forum Electrical & ICE (including SatNav)
    Last Post: 29th May 2007, 08:24
