Thread: Radio Staying on and doors not locking.
    Oct 2012
    Mauchline
    Default Radio Staying on and doors not locking.
    Was just wondering if anyone could give me some info about my car. I have a 2007 face lift 1.8 sri which i have only had two months. Last weekend my car started playing up and the doors arent opening or locking with the fob you have to use the key in the drivers door jump inside and open the rest from the inside. Also the when i turn the ignition off the radio stays on and when i open the door it starts too beep as if i have left the lights on or something on. Then on tuesday it took me 4 attempts to start my car as if the battery was flat and then every morning since it has started first time but does sound as if its struggling any info would be greatly appreciated. Thanks.
    VIP-Member Das's Avatar
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    The radio stays on until you pull the key out the ignition fella. And the beeping when you open the door is to let you know the key is still in the ignition.
    Sounds like the battery in the fob is goosed, and the battery under the bonnet is knackered too to me.
    Oct 2012
    Mauchline
    Sorry shoud have explained tht better it stays on when the key is out and it also beeps when i open the door when the key is out.
    leeds
    This can happen when the ignition lock switch jams. Bacuse it is stuck/faulty it thinks you have the key in the ignition all the time. This is why you get the bongs when you open the door and also why the fob will not lock /unlock. Could also explain why it would not start if the ignition switch is not making proper contact. The radio of course will not go off until it thinks you have removed the key.
    I think you can replace the ignition switch separately from the lock mechanism as that is all you need.
    Oct 2012
    Mauchline
    That could be The problem if i remember when i had key in the ignition it would not turn and and the steering locked on and thts when all the problems started.
  1. Doors keep locking?
    By rob10 in forum Electrical & ICE (including SatNav)
    Last Post: 27th June 2011, 22:08
  2. Having problems locking the doors!
    By bizerk in forum Vectra C / Signum Troubleshooting
    Last Post: 17th December 2009, 16:51
  3. Remote Central Locking - press open just once for all doors?
    By petesaysblimey in forum Electrical & ICE (including SatNav)
    Last Post: 21st April 2009, 08:54
  4. Auto Locking doors
    By mickontherun in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2008, 10:22
  5. Auto locking doors
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2008, 13:14
