Thread: vectra cdti problem camshaft sensor
    Nov 2012
    ireland
    Default vectra cdti problem camshaft sensor
    hey guys im new here ! ive recently bought an 05 vectra cdti 150bhp, car is fantastic and the newest of a long line of opels ive owned ! but its showing a fault P0340 of camshaft sensor, i got a new one from opel but still no good, same problem, ive checked wiring to the sensor and getting a good earth and 5v feed and 4.7 v on idle on middle wire? also plugged in a tech 2 and the live feed shows the camshaft as being right, i.e half the rpm, so im wondering is there anything else that would cause this fault to show? could it be ecu? car also is laggy down low an heavy enough on diesel, ive cleaned egr, the manifold was completely clogged but didnt make a difference, still showing camshaft sensor fault! can anyone help me!?
    Nov 2012
    ireland
    anyone
    Regular Member shinyb1's Avatar
    Jul 2011
    wigan
    sometimes when you fit a new part you need to have the fault cleared , i had this on a bmw when i fitted the new part the fault was still there . so i disconnected the battery over night and it cleared itself - try that .
    Regular Member mike.'s Avatar
    Oct 2012
    peterborough
    Trim : SRi NAV
    Engine : 1.9 CDTi 120
    I had this on a cdti 120 a few months back, kept showing the fault even after 2 new sensors.turned out to be a broken key way on the crank pulley allowing it to slip and so the timing moved a little. Put a new pulley on and retimed it and all sorted!
    As said this was on a 120 but I should imagine it could happen to a 150 as well.I have known about 3 other people to have this also.
    Not a nice job to check as the timing belt needs removing in order to get the pulley off.
    Hope this helps?
    Oct 2012
    peterborough
    Trim : SRi NAV
    Pm me if you need anymore info?
    Nov 2012
    ireland
    cheers dude ive heard of that happening alright but duno if it affects the 16v ones, ill check it tomoro oh and i have op com so i cleared the code!! but keeps coming back
    Oct 2012
    peterborough
    Trim : SRi NAV
    Sounds like the same symptoms are the one I did, does it have poor starting at all?
    Nov 2012
    ireland
    bump this! today i glue mani flaps open, cleaned egr, cleaned boost valve starts way better hesitation at about 2k is gone, but still laggy untill 2.5k and still throwing code for camshaft sensor, thinking now its either timing off a tooth, or the key way in pulley, does that affect the 150 bhp models ??
    Oct 2012
    peterborough
    Trim : SRi NAV
    Might be worth giving your local dealer a call to see if the 150 engines suffer the same.might use the same pulley
    Nov 2012
    ireland
    bump, anyone have any info opel didnt no, very little 16v ones sold over here!
  1. HELP - where is camshaft sensor.....
    By sri150 in forum Engine & Drivetrain
    Last Post: 30th December 2013, 18:24
  2. camshaft sensor reading problems with cdti 150
    By alan opel in forum Engine & Drivetrain
    Last Post: 23rd December 2012, 13:03
  3. Camshaft sensor Q?
    By Barlow in forum Engine & Drivetrain
    Last Post: 11th April 2012, 23:03
  4. Vectra C 2.2 Camshaft sensor
    By robert31 in forum Vectra C / Signum Troubleshooting
    Last Post: 8th May 2011, 23:33
  5. camshaft sensor
    By lusk in forum Engine & Drivetrain
    Last Post: 6th March 2011, 19:30
vectra 1.9 cdti camshaft sensor fault
vectra 1.9 cdti cam sensor location
vectra c cdti cam shaft pulley
vauxhall vectra camshaft sensor problem
cam position sensor for 2007 vectra
1.9 vetra 08 cam sensor problem
does a vauxhall vectra have a crankshaft sensor and camshaft sensor
vauxhall vectra c 1.9 cdti camshaft sensor
cam shaft sensor for 1.9 cdti
vectra 1.9 cdti crank sensor location
vectra cdti cam sensor fault
vectra cam sensor fault
vauxhall vectra 1.9 cdti camshaft sensor location
vauxhall vectra cdti 120 camshaft pulley www.vectra-c.com
astra 1.9cdti 150bhp crank sensor symptoms
vectra c 1.9 cdti camshaft sensor location
vauxhall vectra 1.9 cdti camshaft sensor location 2010
1.9 cdti camshaft senzor
vectra c 1.9 cdti crankshaft sensor location
vectra c 1.9 cdti camshaft pulley
zafira 1.9 cdti cam sensor position
vectra c 120 cdti camshaft
opel zafira 2005 2.2 camshaft sensor location forum
vauxhall zafira 1.9 cdti cam sensor
