Thread: calling fifers!
    Regular Member _kingus_'s Avatar
    Jul 2011
    fife
    confused calling fifers! help needed!
    hey guys!
    I have a engine check light appear on my last night when i was driving, done the pedal test and it showed P0301 misfire in cylinder 1, also the engine is shaking a lot when idling. I'm ruling out spark plugs because I changed them very recently, suspecting coil pack, this is why I'm starting this thread, wondering if anyone is free and will to let me use their coil pack very quickly to see if it changes the way the engine runs before I fork out the money on something that I didn't need?
    any tips on what it may be and a lend of a pack will be much appreciated
    VIP-Member Das's Avatar
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Rule out the spark plug by swapping them around, reset the fault code and start it up.
    wirral
    39 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Pull coil pack off.
    dont rule out plugs until thrive physically been checked.
    If ok put spark in coil.
    Use small piece of wire or press spark thread against engine block to ensure its earthed.
    get someone to crank it. If you see a spark then coil is firing.
    Jul 2011
    fife
    The reason i changed plugs in the first place was that it game me the same code :S but I'll do it just for safe measures =)
    Critch I'll try that tomorrow
    Thanks for the suggestions guys =]
    Jul 2011
    fife
    coil is not firing in first cylinder..
    so back to the same question then, anyone in fife dunfermline area willing to let me try out their coil pack before I fork out money to replace it?
    May 2008
    Falkirk, Scotland
    I have a 1.8VVT (Z18XER) coil pack that's dead on cyl 3 if you want to try it (see my post about spitting out spark plugs!). I'm in Polmont (Falkirk) if it's any use to you?
    Steve
    Jul 2011
    fife
    Thanks for the reply, but I've took the coilpack and spark plugs out for inspection and looked like cylinder one has not been fired at all judging by the plug looking like new (woops). So I done the test Critch suggested and the plug was not firing in the first cylinder, and was with the others.. That confirmed that it was the coilpack =] New one was bought and fitted, car runs perfect now, thanks for all the help guys!!
  1. Gsi ,vx calling
    By noudder72 in forum Engine & Drivetrain
    Last Post: 24th April 2011, 19:07
  2. The DMF is calling me,
    By DavieVectd120 in forum Diesel Engine related
    Last Post: 11th April 2010, 12:25
  3. Calling Aja
    By andy.l in forum General Chat
    Last Post: 14th September 2007, 12:41
  4. Calling AF
    By marichrd in forum Vectra C / Signum Car Chat
    Last Post: 9th July 2006, 21:50
  5. Calling ALD.....
    By Big Davie in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2006, 14:35
