Thread: Faulty Thermostat? & Loss of Power
    Oct 2012
    Swansea
    Default Faulty Thermostat? & Loss of Power
    Hi Everyone
    I currently have two problems that I need a little advice on.
    Faulty Thermostat?
    My car takes about 15-20 mins (6miles) to get to normal operating temp and when it does it fluctuates between 82 and 88. As like earlier, I was sat at lights and the temp was showing 82 when I pulled off I go upto 70MPH (Dual Carriageway) and the temp shot upto 88 and then once i slowed down to around 30 mph it drops to around 85, then it hovers around 82 to 86 driving on residential streets.
    Do you think I have a faulty thermostat?
    Loss Of Power and No Turbo
    Now in the last week or so when i rev my engine I can hear what sounds like air being sucked in. The noise seems to be coming from the air filter area. I'm leaning towards a split intercooler pipe as I have very little turbo power and mpg is crap (100 miles to twenty quid). I'm not very clued up on cars so don't know what pipes I should be checking.
    It has been on a diagnostics machine and the only thing showing is that it needs new glow plugs. EGR valve as been checked and cleaned
    The model is Vevcra 1.9 SRI 150
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Thermostat sounds ok mate.
    Need to check for small splits etc if you get someone to hold revs on a bit you'll probably be able to hear/ see any blowing ouout failing that find a garage with a smoke pro and it'll find it in about 30 seconds
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    As above... Thermostat sounds spot-on. It will run a little cooler with this drop in temperature during winter
    Oct 2012
    Swansea
    Thought I give an update. The car went on a smoke pro and the air leak is coming from the intercooler it self which is goosed.
    Does anybody think this is what making my engine stall when approaching juntions and at idle? Also have very little turbo power and crap mpg
    Oct 2012
    Swansea
    The car stalling when approaching junctions and at idle was due to the EGR gaskets needing replacing. The car was stalling twice a day before but since i've changed the gaskets it hasn't stalled in 500 miles. They did look a bit worse for wear
  1. Faulty thermostat on 2004 Vectra??
    By Meerkatonacid in forum Engine & Drivetrain
    Last Post: 13th June 2012, 19:27
  2. signum 2.0t coolant loss and faulty temp gauge
    By catbic in forum Engine & Drivetrain
    Last Post: 25th July 2011, 09:42
  3. Faulty thermostat, does it damage the engine ?
    By deanos in forum Vectra C / Signum Car Chat
    Last Post: 3rd May 2011, 07:23
  4. faulty thermostat/limp mode/spanner light
    By collyb in forum Engine & Drivetrain
    Last Post: 19th April 2011, 20:20
  5. Faulty thermostat fixed.
    By videodoctor in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2008, 02:32
loss of power faulty thermostat
