Thread: cold morning driving
    Oct 2012
    staines
    Vehicle : Vectra c
    Trim : Saloon
    Engine : 1.8
    Year : 2002
    Mileage : 101000
    Default cold morning driving
    can someone help me....
    I had this problem about a month ago when we had a cold spell but sorted itself out once the weather warmed up slightly. this morning the temperature was -2.5 when I left for work.. only when I start the car in the cold I have this problem where my rev, Speedo, fuel and temperature gauge drops to zero the battery and abs light come on but I can still drive. is this a battery fault and it's the cars way of saving battery power??
    Regular Member shane31's Avatar
    Sep 2011
    Staffordshire
    This maybe a shot in the dark but it sounds like a problem i had last winter. I was driving then all the clocks went off had to stop then restarted and it was fine.. But it kept happening so i found on here that some times cleaning the contacts on fuse 17 would fix this issue. It did! Well for me any way. Good luck...
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    Alternator? Too much draw going through it as you have all the electrics running? Heaters etc... batteries dont like the cold. Just starting it takes a fair bit of effort.
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Regular Member fistymus's Avatar
    Sep 2012
    Saltburn-by-the-Sea
    Vehicle : 1.9CDTi (120) Estate
    Year : 55
    Mileage : 126000
    Quote Originally Posted by nick6515 View Post
    ...is this a battery fault and it's the cars way of saving battery power??
    Once the engine is running it no longer uses the battery as all the juice is supplied by the alternator.
    If the battery light comes on whilst the engine is running, then it's usually an indication of a failing/failed alternator as the car will have to use the battery, thus flattening it.
    If the car starts up ok (Not slowly turning over etc) then that would indicate the battery is ok.
    I would either measure the voltage from the alternator or have it checked by an auto electrician if you don't want to get your hands dirty
    wirral
    26 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Measure batt voltage static, cranking an running
    May 2012
    UK
    I have this exact issue at the moment! I'll also try cleaning the fuse. I also read the ABS sensor can cause this - anyone have any ideas?
    Sep 2011
    Staffordshire
    Quote Originally Posted by Chip View Post
    Yes depending on year....
    May 2012
    UK
    Quote Originally Posted by shane31 View Post
    Well mine is an '06 vvt - does this qualify?
    Oct 2012
    staines
    Vehicle : Vectra c
    Trim : Saloon
    Engine : 1.8
    Year : 2002
    Mileage : 101000
    mines. a 2002 1.8ls did the abs sensor affect this year
  1. Replies: 2
    Last Post: 28th July 2011, 13:37
  2. Driving to work this morning
    Last Post: 9th March 2009, 10:31
  3. Cold morning
    By ed taylor in forum General Chat
    Last Post: 15th November 2007, 18:09
  4. Cold Morning!
    By SignumPhil in forum General Chat
    Last Post: 18th October 2007, 13:13
  5. How cold this morning !!!!!
    By Drinky in forum General Chat
    Last Post: 18th September 2007, 18:27
