Results 1 to 10 of 17
Thread: Replace cv joints or whole driveshaft?
    Regular Member rockafella8587's Avatar
    Nov 2011
    Akrotiri, Cyprus
    Default Replace cv joints or whole driveshaft?
    Which is the easiest or quickest job? I need both inner cv joints replaced. I have found replacement driveshafts that are used but in good nick off a low mileage car. As far as labour costs are involved, is it cheaper to replace the whole driveshaft, both sides. Or just the inner cv joints? Cheers
    Regular Member blue estate's Avatar
    oh well.. I tried..
    Same amount of work involved with labour as you have to take the shaft out to get the inner joints off.. labour times and cost are pretty much the same whatever route you decide
    Nov 2011
    Akrotiri, Cyprus
    Ah ok, cheers mate. Will prob just get the driveshaft replaced then. Easier to track down than the individual inner joints on their own.
    oh well.. I tried..
    Check these lot out.. www.jandrcvjoints.co.uk
    Nov 2010
    East Midlands
    Trim : design
    re J and D - I always find is simpler and cleaner to replace the whole driveshafts - I would be wary of fitting s/hand ones as on the bench they feel fine - it's when under all the forces that are involved when fitted that you may discover problems with them.
    Nov 2011
    Akrotiri, Cyprus
    Had a look on that Jr website, great prices but I can't see any driveshaft for a vectra c?
    oh well.. I tried..
    Part number you want is DS372.. same for both sides and new units.. just phoned them
    Nov 2011
    Akrotiri, Cyprus
    Aw mate cheers for that! I will give them a call shortly and order them then. Happy days!!!
    Aug 2011
    Bristol
    Anyone know how much/hours it would be for a garage to change (yet to look at haynes)?
    I have a mobile mechanic that helps when I need it. How long would it take if all parts but shaft removed ready?
    Please don't tell me the steering arm needs removing for this?
    I know it's cold but is this possible outside the house?
    Nov 2011
    Akrotiri, Cyprus
    Ordered! £59 per side including postage and vat A fraction of the price VX charge
  1. Inner CV Joints
    By Gmc12 in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2013, 17:22
  2. CV Joints / Driveshaft
    By VXR_DV in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2011, 21:11
  3. bad joints on pcb
    By hippo in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2011, 08:31
  4. Inner Tie Rod Joints
    By Electricdave in forum Suspension, Wheels & Brakes
    Last Post: 8th June 2010, 19:29
  5. cv joints compatability
    By dan the man in forum Suspension, Wheels & Brakes
    Last Post: 21st July 2009, 21:09
vectra c c. v.joints fit new
