Thread: Eml light
    Jun 2012
    Harwich essex
    Vehicle : Vectra c facelift
    Trim : 1/2 leather vxr
    Engine : 19 cdti
    Mileage : 70,000ish
    confused Eml light
    just blanked off egr and no light has come on is this the normal thing called txautosport and asked about a remapping but not got the funds at there prices at the moment the man there said to drill about 30 1\2inch holes in to the bottom of air filter dox and this will get more in to the system quicker will this do anything or was they pulling my leg
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    They are talking balls!! DO NOT DRILL THE AIR BOX.
    If you drill it, you will draw in hot air, dropping performance at bottom end and reducing fuel economy. The box is restrictive but to over come this, goto Halfords, get some cheap 50 or 55mm flexible ducting, cut a hole the the bottom section to accept the ducting and pipe in a second cold air feed.
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Quote Originally Posted by nutron View Post
    How badly are the intake tempatures affected with a second cold air feed and is it worth doing?
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Am with Karl utter crap lol
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Nice way to reduce performance with heat soak.
    No doubt they'll try sell you a full cold air fed induction kit with your map due to reduced performance due to heat.
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Intake temps will not change with a second cold air feed, it is coming from the same place :/ If you drill the box though the temps will rise.
    Jun 2012
    Harwich essex
    Engine : 19 cdti
    Mileage : 70,000ish
    thanks for your anwsers when cutting the hole into the bottom section do you do it below the air filter drill on the engine side so the ducting comes out of the air box were does the other end of the ducting o in to
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    Take a look through this thread mate.
    http://www.vectra-c.com/forum/showth...ink&highlight=
    Jun 2012
    Harwich essex
    Engine : 19 cdti
    Mileage : 70,000ish
    thanks for that thread mate off to the scrap yard we go to get a new box after taking notice from the guy at txautosport i think i get more help from people on the forum than the garages i call
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 4
    Last Post: 18th August 2012, 08:58
  3. Replies: 17
    Last Post: 16th August 2012, 10:07
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Fitted rear light,illuminated sunvisors and map reading light
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 10:51
vectra vxr drilled airbox www.vectra-c.com
