Thread: Lambda sensors...
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Default Lambda sensors...
    Took my car into my local garage/exhaust place yesterday to fix a snapped exhaust support bracket.
    I wastched,as I allways do and was surprised to see the earth clamp of the welder being attached to the rear lambda sensors. Didnt say anything at the time tbh.
    Anyhow the repair,which became repairs was foc.Result.
    Driving last night I noticed the EML on...hmmmmmmmmm
    Back to the garage today. A snap on diahnostic tool was used to identify a fault with the second lambda sensor.Fault cleared,just in case.Engine run and the EML came on again.Same fault. Cleared again and fault then confirmed with a 'LIVE' read.
    Outcome Im getting a new lambda sensor fitted tomorrow foc...Yeahh.
    Why would the sensor go through being used as a grounding point??...
    What does this sensor actually do?
    Regular Member fistymus's Avatar
    Sep 2012
    Saltburn-by-the-Sea
    Vehicle : 1.9CDTi (120) Estate
    Year : 55
    Mileage : 126000
    It would be damaged as running anything upto 200amps (depending on welder being used/setup etc) would tend to destroy electrical sensors... This is why you use a bit of chassis or something close to the weld area which isn't actually a sensor
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Amperage running through sensor probably killed it
    it they work by sensing oxygen content and sending info to ecu which will adjust fuel accordingly.
    thats the simplest way to explain them
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Or use oxy/acetylene
    I hate using arc/mig near electronics especially Jags
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Appreciate the responses...am pleasde I didnt do it as the sensors £65.
  1. EML 2.0T Lambda or CAT
    By a1ant in forum Vectra C / Signum Troubleshooting
    Last Post: 20th August 2011, 20:53
  2. Cat Or Lambda
    By Tam80 in forum Vectra C / Signum Car Chat
    Last Post: 6th July 2011, 21:03
  3. Lambda sensors......
    By david.aka.judas in forum Vectra C / Signum Car Chat
    Last Post: 2nd August 2010, 07:51
  4. Lambda sensors
    By 1.9Cdti Elite in forum Engine & Drivetrain
    Last Post: 13th December 2009, 11:18
  5. Lambda
    By VECTRAMAN in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 10:33
z20net earth points on engine
