I have a very annoying intermittent problem with vectra c 52 plate tailgate open warning. I have looked at other threads on here which are similar but not quite the same.
What I need to know is, Can you buy the micro switches that are inside the lock itself. If I replace the lock you use the original switches as they clip out and are connected to the loom so if it is a micro switch problem then they stay.
Any help would be much appreciated.
