Thread: CD70 satnav not working
    leeds
    Default CD70 satnav not working
    Hi Everyone,
    The satnav on my CD70 has stopped working. The map display shows me somewhere near York but I haven't been there for years
    If you go to the MAIN screen which shows you a direction arrow and road name, I get an indication on the left side which is a GPS icon with a line through it. I assume this means no GPS signal?
    Do I just need a new aerial, has anyone had the problem before?
    David.
    Regular Member mrk's Avatar
    Vehicle : vectra hatchback
    Trim : improving
    Engine : 1.9cdti mas remap
    Year : 06
    if you have the aftermarket gps aerial under dash grill pull it out and stick it on the roof for 20 mins ,it fixed mine if you've got factory fit one may need a new one ,i'd just buy a little gps jobbie and stick it under the dash grill as it will save taking roof lining out
    leeds
    Mine is factory fitted. Think I will have to replace the aerial base anyway because the seal is cracked and it might be leaking a bit. It's getting more comical by the minute as it now puts my position in the sea just off the coast at Redcar
    Found out a new part is £95 at my local main dealer but seen a genuine one on line from another main dealer for £32 so ordered one. Will let you know if that sorts it.
    leeds
    Just wanted to report that I changed the aerial base for a genuine new one and all is well.
    Just FYI taking down the rear end of the roof lining to get to the nut and connector is not as bad as it sounds. BTW mine is a Signum so the Vectra may be slightly different.
    I removed the C pillar trims after unbolting the rear seatbelt mounts. Then I removed the centre rear seatbelt plastic holder which sits in the roof lining. All you need to do then is to pull back the seal from the top of the boot opening, and from the tops of the rear doors to free the roof lining. Now gently pulling the rear of the lining down gives enough space to get a spanner on the nut and reach in to disconnect the connector.
    By the way when you remove the C pillar trim you reveal the curtain airbag actuator - a bit scary . Maybe it would be best to disconnect the battery first, I didn't but got away with no problems
    Regular Member rozzer2006's Avatar
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Engine : 2.8 v6 Turbo
    Mileage : 69k
    Did it fix it??
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Quote Originally Posted by davidj387 View Post
    I'd say so
    leeds
    So would I
    Have put the atlas away for another 5 years!
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Agreed - usually losing your GPS location is the fault of the aerial.
    This is the same for either OEM roof mounted aerials or even the ebay purchased patch aerials.
    New aerial sorts about 95% of positioning errors.
    Once in a blue moon the internal circuitry of a CD70 will fail, but it is quite rare.
  1. SatNav Not working
    By renwich in forum Electrical & ICE (including SatNav)
    Last Post: 19th December 2012, 15:29
  2. Cd70 satnav
    By stanlee in forum Electrical & ICE (including SatNav)
    Last Post: 19th October 2012, 19:12
  3. Post codes in CD70 NAVI satnav - who has this working ?
    By eeyore in forum Electrical & ICE (including SatNav)
    Last Post: 6th October 2011, 16:09
  4. New POI on CD70 SatNav
    By Joneseylah in forum Electrical & ICE (including SatNav)
    Last Post: 25th August 2011, 01:34
  5. cd70 satnav
    By Dippy-Vx-line Red in forum Electrical & ICE (including SatNav)
    Last Post: 19th March 2008, 19:29
