Results 1 to 10 of 16
Thread: Erratic boost on my latest turbo
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Default Erratic boost on my latest turbo
    I have been having difficulty with my current turbo suffering overboost spikes then dropping off dramatically before gradually climbing back towards the target boost. Having cleaned and checked multiple sensors I decided it must be the VNT duty in the map not being compatible with this turbo.
    After some head scratching about how best to approach this, as remote remapping of the VNT would take forever sending maps back and forth and really the duty needed to be setup on the road while driving. To achieve this I dragged the MF2 fuel solenoid controller from my water methanol kit out, coupled it with a pneumatic valve from my Apexi boost controller that lay in the garage and slapped together quickly a VNT controller using boost and rpm feeds.
    The mapping took about five hours and a quarter of a tank of fuel with two people, one driving, the other adjusting the potentiometer for the 500rpm intervals. The results were excellent, hitting peak earlierand holding at that level right upto the red line. So now I have proved the turbo is spot on and the fueling is not an issue but I need to try to translate the output of the controller into something that could be applied in the map.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Hmmm interesting that Carl i have sold my siggy and got a 08 plate cdti 150 last time I spoke tobyoubibsaid inwas gonna get another derv lol this weekend jobs is boost gauge where have you tapped in forthr boost feed mate pipe after the inlet ?
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    So, I have fitted my MF2 in conjunction with ECU control to fine tune the map rather than trying to control it completely. I also re introduced the water/methanol slightly lower in the rev range though cautiously as I only have pressure control due to my MF2 trimming VNT, so no RPM safety locks. The result though have been the fastest spool I have ever seen on this turbo unit. I am hitting higher boost at 2000 and peaking at 2.1bar before 2500rpm. This is ideal as I would expect peak boost at 2500rpm if the boost it maxed by then. The power is up significantly too due to the turbine trim (not as high as the 228 wheel power I had on a larger wheel).
    The down side it I think the clutch is unhappy again. I have already fitted an uprated clutch from Black Diamond and after bedding in, it was holding 380lbft in 4th gear on RS Tuning's rollers. That would mean more torque in the higher gears on the road but I was having no issues at all. So I shall have to drag the car back to the rollers to see how much it is putting down and ring around clutch places but they all poo in their pants if you ask for a clutch to take silly amounts of torque.
    Administrator plasma's Avatar
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    keeps the updates coming Karl
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    it dosnt seem like theres enough surface area for the clutch to grip hold im sure theres something like a multi plate clutch that can handle high torque perhaps it was on the golf gttdi if I remember correctly I dont know if you could adapt something like that
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Multi plate and conical clutches take up more room, so it would require alot of modification.
    Jun 2012
    lancashire
    bell house extension and one longer and one shorter drive shaft and then whatever system inside you chose sounds easy lol well if you have the cash to get it made up
    still with all the power your generating I think the only way your not going to eat clutches and lose power through slipping is with bigger surface area on the clutch
    Im guessing if you put any more pressure on the friction material than you are now with that sort of power your going to rip up the disc and turn it in to powder, also is it only that bit of slip that's stoping your gear box from exploding?
    could you fit a larger radius disc in the bell housing ?
    just thinking that vauxhall use the same engine in some of there vans, do they have a bigger disc to deal with the extra weight of a load? might it fit?
    Jun 2012
    lancashire
    380lbft = 514.63 nm on a box rated at 400nm your a brave man
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Quote Originally Posted by john norris View Post
    Spoons and a number of other VXR owners run more with out issue
    Jun 2012
    lancashire
    does the VXR run an f40 gear box?
  1. no turbo boost
    By emilc in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2010, 17:45
  2. What does your 2.0 Turbo boost to?
    By Mark2.2 in forum Petrol Engine related
    Last Post: 21st February 2010, 14:14
  3. turbo boost.
    Last Post: 21st October 2009, 21:29
  4. Turbo Boost - anyone?
    By Leviathan in forum Engine & Drivetrain
    Last Post: 23rd March 2009, 15:26
  5. Turbo Boost?
    By Jay Kay 313 in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2007, 18:34
turbo boost erratic
