Results 1 to 10 of 20
Thread: vectra dti coolant
    Jan 2010
    norfolk
    Default vectra dti coolant
    hi just changed thermostat and cts sensor on vectra dti 2003 plate and it has taken an hour and a half to get to 88 dgrees but i have noticed that the top of rad is hot and bottom of rad is luke warm is this rite as i do not think it should have took all that while to get there does any body think rad is blocked or is it somthing else thanks
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Was it just ticking over or did you drive it?
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Ticking over puts no load on the engine hence it takes longer to heat up.
    Regular Member fistymus's Avatar
    Sep 2012
    Saltburn-by-the-Sea
    Vehicle : 1.9CDTi (120) Estate
    Year : 55
    Mileage : 126000
    You did bleed the air out didn't you?
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    The Vec has a self bleeding system.
    Sep 2012
    Saltburn-by-the-Sea
    Year : 55
    Mileage : 126000
    East Midlands
    Quote Originally Posted by Das View Post
    Does it? .. Never knew that..Hows this work then.
    Jan 2010
    norfolk
    hi it was just ticking over and did run coolant through till it came out of heater pipe like they tell you in book if i take it for run for 10 mins then do i leave it to tick over and what temp do fans cut in thanks
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    Quote Originally Posted by macdad View Post
    The expansion tank is sighted at the highest point of the cooling system, air naturally rises to the highest point, thus making it self bleeding. If you do a coolant change some say that you can help this along by running the engine with the header tank cap removed. I assume that the lack of pressure allows any air in the system to rise quicker as its no longer under pressure, kind of like when you remove the cap from a bottle of fizzy juice.
    The wifes Punto has the expansion tank on the side of the radiator, meaning it wont bleed back to the expansion tank. The Punto has a bleed point on one of the heater matrix pipes(highest point), meaning you have to bleed this system manually.
    Jan 2010
    norfolk
    thanks so your saying that just fill it up then run it and take for drive until it gets up to temp
  1. Coolant Sign - Vectra 07
    By jlb777 in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2014, 14:33
  2. Vectra 3.2 Losing Coolant :(
    By HelloVauxhall in forum Engine & Drivetrain
    Last Post: 7th November 2012, 20:09
  3. Vectra C leaking coolant - please help!
    By d-suhiti91 in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2011, 13:58
  4. Vectra Spitting out Coolant???
    By Rab in forum Engine & Drivetrain
    Last Post: 30th December 2010, 00:47
  5. 2003 vectra 2.2 dti coolant loss
    By watson2.2dti in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd July 2009, 00:18
