Thread: Replacement springs question
    May 2012
    UK
    Default Replacement springs question
    Hi all
    My Vec is at the main Vx dealer today having a fault diagnosed, they have just called to say that I have a broken front spring.
    I have a used car warranty from the place I bought it (a Nissan main dealer) which apparently they can claim on - but only for one spring . I'm going to pay for the other one myself.
    The warranty company have instructed the dealer to use a non-Vauxhall part to reduce cost but on speaking to the dealer it's a brand they use all the time without issue - I'm not sure of the exact brand.
    My car is only a 1.8 exclusiv ('06) so am I correct in thinking this is ok as the main dealer is supplying and fitting it? I don't have sports suspension as far as I know so I guess it should be ok but I want the car to sit correctly and handle as normal.
    Anyone have any advice on this? Would this part be ok or should I try to get genuine Vx springs?
    Nov 2010
    East Midlands
    Trim : design
    You should always replace springs in matched pairs - as you are doing - I don't think Vauxhall originals are any better than a good quality aftermarket one, I fitted a pair of KYB springs on the front of my 1.9cdti estate and when I compared them to the ones I replaced (which I believe were originals) the coils were nearly half as thick again. Been on two years without any problems. Do you know what brand they are fitting?
    May 2012
    UK
    Quote Originally Posted by alcutler View Post
    Hi, not yet - I'll find out tomorrow. Is there a standard brand the dealerships use aside from the Vx originals?
    The Vx ones are more expensive but if there isn't any difference then that's great. I can appreciate an SRI etc needing specific Vx parts but with mine being a standard car I'm hoping it will be ok with the ride and the height the car sits at etc
    Nov 2010
    East Midlands
    Trim : design
    If they are fitting a matched pair you shouldn't have any problem with the height or handling - and if they are being fitted professionally you should get 12 months warranty on the parts and work they have done.
  1. Rear Springs Replacement
    By MrDerv in forum Suspension, Wheels & Brakes
    Last Post: 4th November 2012, 20:38
  2. replacement springs 1.9 cdti sri
    By sardean in forum Suspension, Wheels & Brakes
    Last Post: 13th May 2012, 00:19
  3. Need replacement springs for SRi 2.2DTi...
    By Innes in forum Handling & Braking
    Last Post: 7th February 2011, 16:53
  4. Replacement Springs Shorter?
    By yoclick in forum Handling & Braking
    Last Post: 8th January 2011, 17:18
  5. front springs replacement
    By mhvcbv in forum Suspension, Wheels & Brakes
    Last Post: 18th November 2007, 14:15
