Thread: Strange drive feeling
    Aug 2011
    Bristol
    Default Strange drive feeling
    I changed most of the drive of the car last year, new drop-links inner/outer steering arms, bushes, rear nanna arms and suspension/spring upgrade to SPAX.
    The car was left standing for around 3 months with the front wheels off the ground.
    Now back on the road and it feels funny on the nearside.
    Steering wheel is out to the left. Feels like a knocking constantly like a door knocking from nearside, especially when you floor it in second. It also feels like the wheel is not going straight, as though the bearing has gone but can't tell if from front or rear. Very slow speeds the wobble is normally felt.
    Now I know the standard links etc aren't the greatest but would any of these be knackered so soon??
    Does this sound like body roll so roll-bars bearing or steering arms gone??
    The only thing I have not changed is the lower control arms front and rear and stabilizers on the rear bar. Should I change these first to see if problem still exists?
    What else could it be?
    Gonna check on weekend for any play.
    Regular Member wildchild's Avatar
    Sep 2011
    west-mids
    Vehicle : vectra c
    Trim : elite
    Engine : 1.9 cdti 16v 150
    Year : 06
    Mileage : 111250
    When you say suspension/spring upgrade ??? have you lowered it or just stiffer springs n shocks. av you had the alignment done. as its always best to if removeing struts. av you changed the front droplinks ?? + when you renew a whole load of things at the same time they tend to show up stuff thats worn if you get my drift hth
    gaz
    UK
    Did you get the tracking done after having the new steering arms? I put new track rod ends on mine over the weekend being careful not to put the tracking out to much. Trouble was, it was out and steering felt very wrong but only on cornering. Had the tracking done this morning and its back to its normal self.
    Aug 2011
    Bristol
    Had tracking done soon after all was on last year, full alignment as I did the rear.
    It was way out when finished, had it done (still needed 1 tyre change) had the tyre changed soon after that and since it seemed out. Needs to be done again though.
    Suspension was lower so 30mm lower (15mm as Direct).
    Looking at other posts it may be a CV but god knows how to find out
  1. strange feeling..
    By twaiter in forum Suspension, Wheels & Brakes
    Last Post: 18th December 2010, 13:38
  2. feeling better
    By baz2003uk in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2009, 21:55
  3. If your feeling a little low........
    By FIL 4822 in forum General Chat
    Last Post: 8th April 2009, 08:06
  4. feeling well pi**ed off
    By andy.l in forum The 'Off Topic' room
    Last Post: 11th March 2008, 03:20
