Results 1 to 10 of 15
Thread: miss firing vectra?
    New Member markydj72's Avatar
    Oct 2010
    WREXHAM
    Default miss firing vectra?
    has anyone got any ideas as to why my 2007 vectra cdti 150 seems to be missfireing under load in higher gears.there are no faults showing up and my local vauxhall fitter has been through the car with tech 2 and cant seem to find anything.the car did go into vauhall with a wiring fault and a wiped ecu and they have reprogrammed ecu with updated software.has anyone got any ideas?could it be a problem with the mapping on the new program?????any advice would be appreciated.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    3rd injector plug
    Faulty / incorrectly programmed injectors
    Blocked / faulty diesel filter
    just few suggestions.
    Sep 2011
    Caerphilly
    Vehicle : saab 93 tid(150)
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    Search my thread "think i have finally cured the famous flat spot/hesitation" there is also a how2 on it mate
    Oct 2010
    WREXHAM
    thanks guys.its doesnt seem to be a flat spot its more like a miss fire doesnt happen in first second or third gear but its quite bad if ur in say 6th on a slight incline and put ur foot down at around 1500 to 2000 rpm.thanks for the advice tho i will try the bps clean out later
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    I would go with what antss says matey tbh
    Oct 2010
    WREXHAM
    thanks guys.i know about the 3rd injector wiring problem but think mine is ok.car is a 2007 and has the blue plastic connectors on the injectors.would tech 2 be able to throw up faulty or incorrectly programmed injectors.my fitter alan has a tech 2 and is an ex vauxhall main dealer fitter now working for himself.he is hoping to come out with me for a test drive saturday to get some live data off it
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Quote Originally Posted by markydj72 View Post
    What speed are you doing
    "6th on a slight incline and put ur foot down at around 1500 to 2000 rpm"
    Jan 2012
    Gloucestershire
    I would go with a fuel problem. For example, restricted injector nozzle holes are more noticeable at high fuelling conditions. Also if the rail wasn't being charged to the correct pressure quickly enough (HP pump or intake to the HP pump not all that it should be) when you stick your foot down, you would see low fuel delivery, but maybe not a misfire.
    As you say you intend to do though, get the live diagnostics and see what it says. Compare against someone who doesn't have the problem if you can.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Stick with what Ant said first m8 eliminate the cheaper of the issues first.
    Jan 2012
    Gloucestershire
    Quote Originally Posted by GazCDTI150 View Post
    Cheapest option is to get the live diagnostic done before you do anything if you have a mate than can help out, especially if you can compare it to another car with the same engine but without the fault. I certainly wouldn't suggest changing anything major before looking at what Ant says first, just saying there are a few possibilities within the fuel circuit.
    I have a 150ps and could take diagnostic readings when I boot it at 1500rpm in 6th if you like for comparison. Maybe there should be a data section on this site for diagnostic comparisons? Might be handy.
  1. Vectra sxi 1.8 16v won't rev. Miss fire. Helpp
    By Arran1993 in forum Engine & Drivetrain
    Last Post: 31st October 2012, 19:49
  2. miss my vectra :(
    Last Post: 11th March 2012, 17:53
  3. Mis firing 2003 vectra 2.0dti
    By dezzypoole in forum Engine & Drivetrain
    Last Post: 11th February 2011, 00:29
  4. Vectra c sri 1.9 cdti 150 real bad miss at 4 grand
    By krisssri in forum Engine & Drivetrain
    Last Post: 1st August 2010, 16:23
  5. vectra cdti slight miss at 1500rpm
    By kamar in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2010, 01:12
opel vectra 2.8 v6 turbo hesitation under 2000 rpm
saab 2.8v6 turbo flat spot hesitation at 2000 rpm
