Thread: What method is used to disconnect door connector
    May 2006
    scotland
    Default What method is used to disconnect door connector
    Anyone, a bit of help would be much appreciated. It was dark so only had a quick look but can anyone help me in the method used to disconnect the front door (passenger) electrical connector (where the cable loom enters the door - the big black connector)?
    The centre console is reporting the door is open but it is not. Only started after very heavy rain so I suspect water ingress.
    Is there a release tab that rquires to be pulled or pressed on the connector etc?
    thanks
    newport
    use a flat head screwdriver to push the release tab upwards, as it comes up it pushes the connector apart
    VIP-Member antowens's Avatar
    Dec 2011
    liverpool
    i know with the rears you squeeze then push innand pull and it releases dont kmow about the front though
    May 2006
    scotland
    Thankyou all.
  1. Door lock 5 pin vs 7 pin connector
    By jaap in forum Vectra C / Signum Car Chat
    Last Post: 13th June 2012, 16:39
  2. How do u unplug Door switch Connector ???
    By Dal5band in forum Bodywork & Interior
    Last Post: 28th March 2012, 23:19
  3. Alarm disconnect
    By VECTRAMAN in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2010, 20:47
  4. Drivers door window switch connector
    By neilt in forum Electrical & ICE (including SatNav)
    Last Post: 15th November 2008, 21:28
  5. Door Switches Disconnect wiring
    By NealM in forum Electrical & ICE (including SatNav)
    Last Post: 14th March 2008, 21:42
