Thread: Oil In The Water
    Nicking Ya Dinner.
    Default Oil In The Water
    Just a note to add to the section.
    I've just had oil residue floating in the header tank, I thought head gasket, but after going in for repair it was the heat exchanger, car is a 2.0DTi and the unit sits just between the oil filter and the engine.
    Symtoms as well as the oil, were when I emptied the bottle the water looked like it was from a bubble lamp, the engine still ran fine and the bottle had emptied itself.
    HTH if anyone else encounters it.
    New Member Mark Swain's Avatar
    Sydney - Australia
    Default Oil In The Water - Its a common problem
    Hi VauxVeteran, you'll find quite a few of us have had similar problems with oil going into the cooling system and causing some major problems. I have a Vectra CDX 3.2 V6 and had similar problems with the Oil Inter-cooler failing and dumping oil into the coolant and coolant into the oil. Watch out for subsequent automatic transmission problems as this usually happens shortly after. Its bad design and bad manufacturing which results in major repairs with a major price tag so hope you are still under warranty. Regardless push the issue with Vauxaul / Opel as they know it their fault and they have to fix it.
    Regular Member HappyHarry's Avatar
    Wolstanton, Newcastle-under-lyme.
    Happened with mine (2.0 DTI) - At 59k.......Phew!
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    Quote Originally Posted by Mark Swain View Post
    dont get the problem with my 3.0cdti as vauxhall fitted a seperate transmission cooler on these models not in the rad like most other models
    Nicking Ya Dinner.
    lucky it dumps oil in the water rather than water in the oil.
    Lisbon
    That's a good hint !!
    I don't have any oil in the water expansion tank, but the water disappears time to time...
    I think its not normal...
    Can anyone help ??
    Eduardo.
    Mar 2007
    Australia
    hm..
    perhaps heat exchanger? radiator?... or some magical evaporation?
    Jul 2006
    Mexico
    Here we are
    http://forum.vectra-c.com/showthread...t=water+matrix
    This covers the most of things of this scary issue ...hope it helps
  1. water water everywhere
    By rob warrington in forum The 'Off Topic' room
    Last Post: 9th December 2012, 00:03
  2. water and oil
    By Tinks in forum Engine & Drivetrain
    Last Post: 16th February 2012, 19:40
  3. What colour is your radiator water bottle water? and head gasket.
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2011, 21:39
  4. help.........water!!!
    By lilangel in forum Vectra C / Signum Car Chat
    Last Post: 29th May 2008, 10:49
  5. Water water everywhere!
    By Big Sig in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2007, 15:09
