Results 1 to 10 of 21
Thread: help needed trying to fit alternator belt
    Sep 2012
    stamford
    Default help needed trying to fit alternator belt
    hi all i have a 2006 1.9 16v cdti, today i tried to change the crank pulley and belt, old pulley and belt came of no problem, for the life of me i carnt get the new belt on or the old one. no idea what is going on, ive checked the new crank pulley against the old one and its the same size, why do the belts seem to small, the old belt is a 61410 the new belt 61413, im turning the tensioner pulley fully clockwise till it wont go anymore, when i turn the tensioner it actually looks like it is tightening the belt not giving me more slack. please someone tell me im stupid and tell me whats going on.
    thanks all matt
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Have you put the belt tensioner on incorrect mate.
    The tensioner wheel will be virtually touching the vibration pulley (outer crank pulley) until you open the tensioner round to fit the belt.
    I may have a pic - let me see...
    Sep 2012
    stamford
    thanks for reply i didnt remove the tensioner, im working from underneath so didnt have to remove airbox etc, do i need to remove the tensioner and fit it after the belt. thanks
    Middlesex
    Trim : SRI
    Mileage : 100k
    Ah Ok.
    No - dont remove the tensioner then....
    Are you sure you have it on the correct route? Sounds like you may be putting it back incorrect.
    Can you get a pic or two of how you are trying to fit?
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    U sure u have same length of the belt? Top 3 are over, bottom far ends are over, one in middle in between is innards. Tenision is innard. Hope that helps?
    Sep 2012
    stamford
    just went to have a look not enough room to take a pic, ive looked on google and on here at a few diagrams and im doing it as there shown, im totally stumped
    Sep 2012
    stamford
    hi yes thats how i have it
    Nov 2010
    East Midlands
    Trim : design
    Sep 2012
    stamford
    yes thats the way i just carnt get it over the bottom idler pulley
    East Ayrshire
    Trim : SRI XP1
    You need to roll the tensioner back, get a spanner or socket on it and turn it clockwise, it should drop allowing you to put the new belt on, When you ease it back it'll put the tension back on. 2 pairs of hands might be helpful but its straight forward enough
  1. New alternator and belt
    By Mark-R in forum Engine & Drivetrain
    Last Post: 14th September 2012, 17:20
  2. Alternator / AUX Belt Change - 1.9 150
    By AlexGSi2000 in forum Engine & Drivetrain
    Last Post: 17th November 2011, 23:47
  3. Alternator Belt! HELP A.S.A.P
    By rwellfair in forum Vectra C / Signum Car Chat
    Last Post: 24th May 2010, 07:43
  4. Signum 2.0t alternator belt
    By turbohaggis in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2009, 11:37
  5. dti alternator belt help
    By rorycarz in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2008, 23:09
vauxhall vectra 1.9 cdti alternator belt
alternator for vectra c 1.9 cdti 16v
how to fit a alternator belt on 2007 vauxhall vectra 1.9 cdti
vectra c 1.9 alternator belt changing
