Results 1 to 10 of 20
Thread: cv joint gone??
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    Default cv joint gone??
    My front drivers side wheel has started knocking/clunking when driving very slow or going around corners,at normal driving speeds its fine.I can also feel it slightly through the pedals a little bit when it happens.Ive also noticed today that if i dry steer(i know im not spose to do it but it was for diagnoss perposes only) theres also the same clunking noise but also the steering is jerky
    I had a quick look behind the wheel and the CV boot seems intact and no signs of wear in the bushes.
    I dont think its suspension related as theres no noise when going over bumps
    Anybody got a ideas what it could be
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Does it clunk when you change gear and release the clutch to bite?
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Steering on full lock and drive off in a circle slowly. A knackered CV joint has a very obvious and noticeable Click Click Click sound too it.
    Middlesex
    Trim : SRI
    Mileage : 100k
    only an outer I think will click click click - if the inner is knackered - the shaft has too much in and out movement causing a clunk but doesnt always click.
    A
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by AntSSSS View Post
    A
    B++++y hell - it will be 'clunk click every trip' next
    Aug 2011
    Basingstoke
    Trim : SRI
    Cheers guys,
    It is more of a clunk thank a click and is more noticeable in the car rather than hearing it outside of the car.Ive had CV joints go in the past but i originaly felt a clunk 2 days ago and now is doing it all the time when turning at slow-medium speeds.
    Either way,is it a hard job to do myself? i couldnt find a how 2 on here for cv joint
    Thanks again guys
    Nov 2010
    East Midlands
    Trim : design
    Easy enough to do - I use these people to supply the joints - very good quality units and the seller is very helpful - http://www.ebay.co.uk/itm/VAUXHALL-V...item27cd28d40c
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by alcutler View Post
    Agree
    Just be aware that he doesnt do the inners.
    On my old car it was the inners that were shot causing a clunk when coming on and off drive.
    I got the full driveshaft with CV's already assembled on them from ECP (approx £80 each side complete all in) and it cured the problem 100% if that helps.
    Aug 2011
    Basingstoke
    Trim : SRI
    ECP want 255 for a complete driveshaft and a oem quality one costs 445
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by justin32 View Post
    DAM they have gone up.. QDrive ones I bought were less than 100 (once you had the surcharge returned) and very good quality.
  1. cv joint
    By beat275 in forum Engine & Drivetrain
    Last Post: 1st February 2013, 15:27
  2. CV joint gone
    By GCusdin in forum Suspension, Wheels & Brakes
    Last Post: 1st December 2012, 20:14
  3. CV joint
    By morri76 in forum Vectra C / Signum Troubleshooting
    Last Post: 28th July 2011, 21:08
  4. C.V. Joint?
    By rosssri in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2011, 21:25
  5. cv joint
    By twaiter in forum Suspension, Wheels & Brakes
    Last Post: 23rd January 2011, 17:08
cv joint clunking on my vectra
