Results 1 to 10 of 14
Thread: ECU Light on, accelerator pedal fault? need wiring diagrams
    Nov 2012
    Ireland
    Lightbulb ECU Light on, accelerator pedal fault? need wiring diagrams
    Hi can anyone help, I have a 2005 Vectra 1.6 petrol, the ecu light comes on after a few minutes when the car engine warms up, this doesn't seem to happen if the car is moving as opposed to idling in traffic. The fault code blamed the accelerator pedal, so I changed this and the problem is still active. I wonder if anyone else is suffering this issue and if they solved it. I have come to the conclusion that it can be 1 of three things:
    1. the accelerator pedal (now changed)
    2. the loom between the pedal and the ECU or
    3. the ECU.
    It would be great if I could get some diagrams and information as to the voltages on each wire in the loom. This way I could test to see if the reported voltages on the ECU match the Voltages at the pedal. I will test the cable for continuity and a load test to see if a conductor has broken down. If that all fails I imagine its off for an ECU fix.
    I would really appreciate any advice or wire diagrams it you have them.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Try cleaning throttle body check for dry joints etc
    we don't have the 1.6 option here but I can try locate diagrams if still no joy
    Nov 2012
    Ireland
    Thank you Critch, this sounds like great advice and something I had not considered, I have now looked at the TB and it looks very dirty on the outside, (quite possibly an indication of the inside) off to get some cleaner to do the job as soon as possible. I will keep the thread posted just in case some one else has a similar issue. It seems rare though because I haven't come across a discussion on this topic before. And thanks again for the really quick reply, much appreciated.
    Nov 2012
    Ireland
    No joy with the clean-up. I used copious amounts of carb cleaner on the throttle body and cleaned out the rubber pipe going to the manifold but this has not worked, I pulled all the plugs on the TB and on the ECU and they all look in good order. When you advice dry joints do you mean inside the ECU?
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Inside the throttle body unit (electronic unit attached to side) theirs a how to some where
    Oct 2012
    Ireland
    I have the exact same problem! I have a 2005 1.6 Vec same as yours and I have changed the throttle pedal, cable and cleaned out the intake manifold and throttle body! brought it too an auto electrician and he put it on his diagnostic and it said:
    Throttle Pos. Sensor 1 and 2
    "Limp-Home" Mode
    I then changed the pedal but still the same problem. I brought it to another auto electrician that had the Launch Diagnostic system (awesome ) and more errors came up such as coolant sensor and this is why we thought it was wiring! He told me to change the throttle body as its the last thing to try i think! Ill be doing it at the weekend so ill let you know if it works!
    (I brought it to an opel garage and they told me they had the same problem with 2 1.6 zafiras and they had to change the ECU -800 quid from opel! Im hoping this was just them trying to get money out of me and its just the throttle body
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    What is the exact fault code and description?
    Oct 2012
    Ireland
    P1550 - electronic throttle control
    P0220 - throttle pos. sensor
    They're the ones I'm getting anyway had this problem for about a month
    Oct 2012
    Ireland
    Ill be going back out after I change the throttle body so can get the printou with the description if it's not working after that!
    Oct 2012
    Ireland
    http://www.bba-reman.com/forums/Topi...px?PageIndex=4
    Really good info on here..I know its for the 1.8 but seems to all end up as an ECU fault
  1. Replies: 1
    Last Post: 20th December 2012, 21:36
  2. Accelerator pedal issues?
    By johnsastra16v in forum Engine & Drivetrain
    Last Post: 20th May 2012, 11:22
  3. Accelerator pedal travel problem
    By AFA82 in forum Engine & Drivetrain
    Last Post: 24th February 2012, 20:42
  4. Accelerator pedal
    By Mopar Man in forum Diesel Engine related
    Last Post: 8th December 2011, 20:41
  5. Accelerator Pedal Removal?
    By OPC in forum Styling
    Last Post: 16th June 2010, 13:39
show wireing diagram ofopel vectra from foot pedal to ecu
throttle paddle piston sakoda rapid wiring diagrams
astra g throttle pedal wiring diagram
vectra 1.8 electronic throttle fault
vectra c wiring diagram
vectra c accelerator not working
vauxhall zafira tps wiring guide
vauxhall astra turbo throttle wiring diagram
wiring accelerator paddle
zafira c throttle position fault
vauxhall astra throttle pedal faults
zafira throttle pedal fault ecu wiring bypass
vectra c accelerator pedal fault code
vectra b accelerator pedal live wires
opel zafira pedal diagrams
astra g ecu wiring diagram
wiring of opel astra throttle sensor
renault scenic accelerator pedal settings
VAUXHALL ASTRA mk4 throttle pedal
vectra c 1.8 faulty accelerator pedal
renault laguna 1.8 wiring design for throttle body to ecu
laguna 1.8 throttle body connector voltages
zafira accelerator pedal wiring
renault grand scenic throttle pedal wiring diagram
www.Renault science 420 wiring diagram.com
