Thread: swirl valve rod
    New Member pha-q2's Avatar
    Nov 2012
    fife
    Default swirl valve rod
    hi i've got an old problem just wondering if there were any new answers it's a vectra cdti sri 150 it looses power and also feels like someone throws a switch and cuts all power then throws it back on again i've had a look at the actuator rod and found it was off the valves 1,2 and 4 valves move freely on there own 3 doesn't as i know it attached to the actuator there is also oil on top of the manifold and around the valves does anyone know if this is the actuator manifold fault or could it be something else like clogged egr valve vauxhall (robbing bas***d) dealer wants £100 + vat to run a diagnostic check
    Nov 2012
    Goole
    Sounds like a new manifold chap, but try the £1 fix first.
    Nov 2012
    fife
    a ha!!!! whats the £1 fix couldn't find the thread for it
    Regular Member wildchild's Avatar
    Sep 2011
    west-mids
    Vehicle : vectra c
    Trim : elite
    Engine : 1.9 cdti 16v 150
    Year : 06
    Mileage : 111250
    Hi mate i wouldnt bother with that fix now id just bond them open now as if you do it right you will sealing the swirl valve which your proberbly loosing boost pressure out of. check out tony-1977(the swirl valve master lol) threads on the £1 fix and bonding them he's done em both hth
    gaz
    Sep 2011
    west-mids
    Vehicle : vectra c
    Trim : elite
    Year : 06
    Mileage : 111250
    Oh yeah just do a search on egr cleaning on here easy to do it your self before paying stealer to do or a new one buddy
    gaz
  1. swirl valve
    By HARRY SRI in forum Engine & Drivetrain
    Last Post: 12th January 2011, 19:10
  2. Egr valve, swirl valve problems etc..
  3. oil and swirl valve
    By POAH in forum Engine & Drivetrain
    Last Post: 28th September 2010, 21:29
  4. Swirl Valve Rod ....
    By denzo in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2008, 19:15
  5. Swirl Valve Q??
    By robdd1 in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2008, 11:30
